Posts: 620 |
Cool, it sounds like your exhaust setup is exactly what I want to get for mine: two magnaflows in the stock pipe.
But first I have to deal with the recurring CEL, and then get the e-RAM working, and flush the brake fluid before my next trip (late July). Then the exhaust. And then, finally, see what I can do for a chip.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 394 |
I'd like to install an exhaust system, but i'm waiting for D DAVIS' CAI first. Hey, D DAVIS? You out there? You listening? Do you see what you are doing here? I can't go on like this!!!! I WANT MY CAI!!!!
=========================================== 1999 Contour SE 2.0 Zetec KKM Sound Enhancer (soon to be tossed aside... D DAVIS) Front Bra Beautiful Girlfriend for a passanger
Posts: 2,148 |
MAGNAFLOW SUX!!!!!
Just kidding.
Redhawk's setup is very nice...very true to the car's european roots...sound is more european than asian, if that makes sense. Got to see it last weekend.
Former owner of 1999 SVT Contour #555
Posts: 139 |
Thanks for the info Redhawk. I have the SHO Shop Y-Pipe and Hi-Flow Cat and also a Magnaflow Stainless Steel Muffler. I removed the resonator and love the sound, but I believe it is too loud and raspy. So, with your advice, I bought a Magnaflow resonator that is currently being shipped and will have it installed when it comes in. I will let you know how it sounds.
Posts: 1,969 |
Good to know this was an informative post. I kinda felt like I was whoring it out a bit John, thanks for the shout out Paul, please keep me up to date on the E-ram. Very interested in seeing how that turns out...
Kharma is very real and she is one mean b!tch.
Posts: 731 |
Force the ATX to downship at 65mph and it will put you into the seat. What do you mean by that? Cutting the O/D off?
Posts: 139 |
Originally posted by redhawk: Paul, please keep me up to date on the E-ram. Very interested in seeing how that turns out... Ditto
99 SE Zetec ATX CTA intake ZX2 FMS wires(that don't fit my oddball coil) andenthal@mindspring.com
Posts: 620 |
Originally posted by redhawk: Paul, please keep me up to date on the E-ram. Very interested in seeing how that turns out... It is still not installed, because I have been very busy at work, and have not had time to resolve the recurring "too lean" CEL problem.
Posts: 1,969 |
Originally posted by Rynn: Force the ATX to downship at 65mph and it will put you into the seat. What do you mean by that? Cutting the O/D off?You can make the car downshift by stepping into the accelerator slighty past half throttle. Most ATX's will do this...
Posts: 29 |
I granted i no nothing about exhaust but i do like the set up that is talked about here. So if i was to reverse the set up and put the 14" Long - 3.5"x7" Oval Muffler in the resonator spot and the 14" Long - 4" dia Round Muffler in the back would the set up still be as effective. See i want to start with the 3.5"x7" Oval Muffler in the resonator spot and cut off the stock muffler and if its to loud place the 14" Long - 4" dia Round Muffler in the back. Will this work?
