Page 3 of 4 1 2 3 4
#298707 05/17/02 10:09 PM
Thanks Lee,
I figured that as soon as I got everything back together. Will have to go and pull the whole dash bezel apart again. Any info on a wiring diagram to tell me which wires control the CEL and the O/D off lights? I want to cut those and solder them back together so they work properly with the new cluster. Thanks again!
On the old cluster there are dummy lights that say "Sport" and one that looks like a shock or something like that. Any clue as to what those would be used for? Thanks!
1997 Contour GL Sport ATX
Zetec/2.0 liter
K&N High Flow Air Filter
Mobil 1 SuperSyn 5W-30
Mobil 1 Oil Filter (M1-204)
Fram Sure Drain System
Ford Motorsport 9mm Racing Wires
Recontented Fog Lights, Rear Dome Light, Underhood Courtesy Light, Glove Compartment Light
Pirelli HPs
Kenwood in-dash CD player
Infinity 5752cf speakers
World Champion New England Patriots Fan for Life!
Wife's Car:
1998 Contour SE ATX
Duratec/2.5 liter
Mobil 1 Oil Filter (M1-210)
#298708 05/17/02 11:31 PM
Z
Z
mine is the same thing but I don't have overdrive...
I think those are lights used on the mondeo... but who knows...
really anyone???? some of the mondeo owners could tell us I hope...
Joe Hartley
"yes I know it's a MTX Zetec but it beats having a ATX Duratec"
Champagne 96 GL MTX some mods
dynoed at 114.2whp and 124.4wtq (pre CTA intake)
16.858 @ 80.76mph (yes it's slow but still faster than D Davis)
AIM: ZetecRacing
My Site My Profile
#298709 06/01/02 03:52 PM
First, does anyone have a wiring diagram with specific functions (CEL, O/D off) outlined for the two harnesses coming from the dash (color/function)? I'd like to cut and solder the two wires that control my CEL and O/D off so that they work correctly. As it is right now, my O/D off light is functioning as my CEL (not a big deal), but when I press the O/D button nothing comes on (I would have assumed my CEL would have come on). Any help will be very appreciated.
Hi. Just joined the forums, so sorry for the delayed response.
According to the '98 wiring diagrams I have, both CEL and O/D off lights come from BK/OG wires. The CEL wire is 0.5sq.mm, while the OD off wire is 0.35sq.mm... so presumably the thin BK/OG is OD off while the thicker is CEL.
Swap these and you should be in good shape.
Hope this helps!
98 Contour GL (Champagne)
Zetec / ATX
Mods: Blown head gasket
#298710 06/01/02 05:03 PM
Thanks for the info. Unfortunately, I already attempted to install the new cluster and the damn thing started smoking as soon as I connected the harness to it. A bunch of circuits on the board opened and now all I have is a whole bunch of extra cluster bulbs. A hard lesson learned, but one that I will never try again. I'm pretty sure that there was a problem to begin with on the speedo board, but had no way of knowing that because I bought it on Ebay. The guy didn't tell me that the board had open circuits on it and now he won't give me my $$$ back. Sorry to ramble on, I just needed to vent mad . Thanks again!
Zetec/2.0 liter
Pirelli HPs
Wife's Car:
1998 Contour SE ATX
Duratec/2.5 liter
#298711 06/01/02 10:58 PM
Z
Z
there had to be something wrong with the board cause I have had in my 96 the original, one out of a 98.5 SVT, 98SE, 2000 SVT and the 97 mystique 4 banger that I currently have and had no problems with them smoking the SVT ones everything worked but the speedo...
Joe Hartley
AIM: ZetecRacing
My Site My Profile
#298712 06/04/02 07:42 PM
9
9
question question if i find a 1996 atx contour wiht a tach will it work perfectly in my car or does it matter if it is a v6 or not im trying to match model years and transmissions in hopes of not screwing anything up.
1996 Champagne GL 4-banger (ATX)
(I miss you baby)
AIM:DJT81185
Replaced with
1998 Neon Coupe DOHC 5-Speed
R/T 1.084
60' 2.549
330' 7.112
1/8 10.872
MPH 65.15
1000' 14.111
1/4 16.825
MPH 83.12
#298713 06/05/02 01:07 AM
If the cluster is from a V6 it will function but the tach probably won't read at the proper RPM's. There is a resistor and diode on the back that(I think)needs to be swapped out to a different value for the tach to read the signal right. Transmission doesn't seem to matter from what I've gathered and even the year is variable. My cluster is from a 99 Mystique ATX...I got a 96 Mystique cluster for a guy in OK with a 96 or 97 with manual, so far its working good.
#298714 06/05/02 03:45 AM
Z
Z
see my post on the bottom of page 1... everyone I have had in mine V6 except for the one out of the mystique... and ALL of them the tach worked and read correctly... just the SVT speedo doesn't seem to work on the pre 98's
Joe Hartley
AIM: ZetecRacing
My Site My Profile
#298715 06/05/02 05:15 AM
Interesting, thanks. I think it was baco99 that got a cluster some time ago...something about the tach didn't work right. I think he said it was from a V6. I could be wrong though. wink
#298716 06/05/02 05:54 AM
I know all about that. mad
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Page 3 of 4 1 2 3 4
