Posts: 2,657 |
Originally posted by ZetecRacing: mine says 'normal' on the original and the new one. Well, I was talking to J. Salvi but your info is useful as well.  It seems to help determine(right away)whether or not the cluster is from a 98 or 98.5. There were some changes in between there that make the guages harder to work with.
Posts: 2,143 |
You wanna know something weird....? If what you say is true...the 95s are cable driven.... well I have a 95 and my sport cluster is electronic!!! I have the tach and the speedo, and its electronic, and its a 95!! any thoughts?
'95 Tour LX ZETEC MTX TOO MANY MODS TO LIST ANYMORE!! http://www.geocities.com/marine113 Best mod ever to my tour: A Beautiful passenger seat filler, that is my Beautiful Girl!!
Posts: 174 |
The cluster I'm hoping to get has the red bar on the right and the white bar on the left with the word "normal" in between them for the temp guage. The fuel guage is different than my 97 as it doesn't have the red bar on the left and doesn't say "1/2" in the center.
1997 Contour GL Sport ATX Zetec/2.0 liter
K&N High Flow Air Filter Mobil 1 SuperSyn 5W-30 Mobil 1 Oil Filter (M1-204) Fram Sure Drain System Ford Motorsport 9mm Racing Wires Recontented Fog Lights, Rear Dome Light, Underhood Courtesy Light, Glove Compartment Light Pirelli HPs Kenwood in-dash CD player Infinity 5752cf speakers World Champion New England Patriots Fan for Life!
Wife's Car: 1998 Contour SE ATX Duratec/2.5 liter
Mobil 1 SuperSyn 5W-30 Mobil 1 Oil Filter (M1-210)
Posts: 2,657 |
It's probably an early 98 then, you should be okay. You may need to swap the fuel guage between your cluster and the new one...sometimes they read backwards between model year clusters. And, the needle on the temp guage may need to be reset so it reads correctly...may read too low or too high right after swap. smoothy, Got me, are you sure you have a 95??
Posts: 9,178 |
Well, as much as I hate to agree with Smoothy.....I found a 95 Mystique in a salvage yard by my house that had an electronic cluster.
Posts: 1,692 |
Originally posted by Pollo_loco69: Well, as much as I hate to agree with Smoothy.....I found a 95 Mystique in a salvage yard by my house that had an electronic cluster. could be a late 95 almost a 96 then... my 96 came with 15" rims that weren't avaliable on the tours till 97. mine was made mid June 96 almost the end of the production run for that year.
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 9,178 |
Could be. Don't know for sure. I didn't get it because I wasn't sure if it would work with my 99 or not.
Posts: 3,950 |
I'm telling you.... freaking Fords!
Posts: 174 |
Hey guys, Finally got the cluster installed today and have a few questions. First, does anyone have a wiring diagram with specific functions (CEL, O/D off) outlined for the two harnesses coming from the dash (color/function)? I'd like to cut and solder the two wires that control my CEL and O/D off so that they work correctly. As it is right now, my O/D off light is functioning as my CEL (not a big deal), but when I press the O/D button nothing comes on (I would have assumed my CEL would have come on). Any help will be very appreciated. Second, is there a cluster light that indicates your fog lights are on? I'm pretty sure the cluster has one and just wanted to know how I could get it to work.
Posts: 1,559 |
You need to replace the bulb for the CEL it's burt out. Just take it out of your old cluster.
