Posts: 825 |
Adam
Electric red 95 Ford Contour GL ATX Zetec Born on date 11/1/94
Big changes coming......."hint 95 Ford Contour SVT".
"This is a place for crazy people I'm not crazy." Brad Pitt [12 Monkeys]
Posts: 1,692 |
Originally posted by andenthal: What did you use to go by? Instructions I mean. Haynes manual? So now when you turn the OD off, what does it show? Nothing? I don't have over drive cause I have a MTX so no need to know...
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 1,692 |
Originally posted by Rynn: What did you do about your odometer? Is there a way to up the milage if you find one that has less miles than you? trying to figure that out as I type this... justt need to figure out how to unhook the speedo from the cluster on the back side.
Posts: 1,692 |
you just gotta get one out of a 95 cause of the OBD 1
Posts: 669 |
FYI......proper name for the tan interior is the wonderful pumice
-chris- 96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Posts: 1,040 |
Originally posted by ZetecRacing: ....... I got this from JontourSVT he found it in a bone yard on a 97 Mercury. .......... one problem is I have no check engine light with it instead it is the overdrive off light that I get instead. .......... horseydug: it is something tan can't remember the exact name. A Contour without a CEL, now there's the ideal car. My stock '98 has o/d light in same place and the check engine light is the first warning light to the right of center maybe you can rewire to it. tricked96: Thanks re the '97 "Pumice" color, which presumably applies to exterior as well. Ford switched to Prarie Tan in later years, a wise decision IMO.
Posts: 1,969 |
Kharma is very real and she is one mean b!tch.
Posts: 1,559 |
Originally posted by Rynn: What did you do about your odometer? Is there a way to up the milage if you find one that has less miles than you? Well on the electric speedometer cars you could unhook the cluster and apply the correct voltage to get it to spin up. On the 95's you can get a "HIGH" speed drill and spin it up. The other option for both is that you can dis assemble the speedometer and manually reset the numbers. I don't recommend this if you've never done this before as it's very tedious work.
Posts: 1,692 |
Originally posted by horseydug: Originally posted by ZetecRacing: [b]....... I got this from JontourSVT he found it in a bone yard on a 97 Mercury. .......... one problem is I have no check engine light with it instead it is the overdrive off light that I get instead. .......... horseydug: it is something tan can't remember the exact name. A Contour without a CEL, now there's the ideal car. My stock '98 has o/d light in same place and the check engine light is the first warning light to the right of center maybe you can rewire to it.
tricked96: Thanks re the '97 "Pumice" color, which presumably applies to exterior as well. Ford switched to Prarie Tan in later years, a wise decision IMO.[/b]the exterior is Champagne if you have the golden color.... see my profile to see extereior color... I was that the CEL is where you said but I am too lazy to do a rewire to make it work and since I know what light is the CEL I will make due with it as it is. looking at my old cluster I found ALOT of ODD lights on it like one that shows a pic of a strut, and one that says sport, and another one that shows a fan with a radiator behind it... all of these didn't have lights in the socket from ford... anyone ever see them on theirs?
Posts: 567 |
Glad it worked for you, looks great. Anyway, try replacing the bulbs in the CEL slot, that may do the trick...
CURRENT RIDE: 95 GL FORMER RIDE: 99 SVT ( www.mysvt.com) "You only live once, but if you lived my life, once would be enough." -Frank Sinatra
