Posts: 1,692 |
Originally posted by JontourSVT: Glad it worked for you, looks great. Anyway, try replacing the bulbs in the CEL slot, that may do the trick... already tried that problem is the OD light is where the CEL is on the original cluster.... OOH WELL
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 3,950 |
Posts: 2,657 |
I believe the pre98's are setup similiar to the 98+ regarding the TACH/odometer. If thats the case then you can remove the entire speedo/odometer guage from behind the face and swap between the two. Thats what I did for mine...no issues so far. The early cars may have some differences though. Joe, Email me and I'll send a pic of the two speedos from my two clusters...I'll bet your speedos have similiar(if not identical) part numbers as mine do. IIRC both of the circuit boards for my speedos have a 96 part number....errrr...engineering number...whatever you wanna call it. sqplus@my99svt.net
Posts: 763 |
not all 98+ models have the same type of plug in for the gauges
Posts: 174 |
Does anyone have an instrument cluster (w/ tach) schematic for a 98+ Zetec cluster? I have one that I want to install but something on the speedo board is fried because when I attempted to install it the other day, smoke started coming from the connector. Do the cd-rom manuals come with detailed schematics? If so, could someone send me one via email? Thanks for your help!
1997 Contour GL Sport ATX Zetec/2.0 liter
K&N High Flow Air Filter Mobil 1 SuperSyn 5W-30 Mobil 1 Oil Filter (M1-204) Fram Sure Drain System Ford Motorsport 9mm Racing Wires Recontented Fog Lights, Rear Dome Light, Underhood Courtesy Light, Glove Compartment Light Pirelli HPs Kenwood in-dash CD player Infinity 5752cf speakers World Champion New England Patriots Fan for Life!
Wife's Car: 1998 Contour SE ATX Duratec/2.5 liter
Mobil 1 SuperSyn 5W-30 Mobil 1 Oil Filter (M1-210)
Posts: 3,950 |
So am I.
Posts: 55 |
>I found ALOT of ODD lights on it like one that shows a pic of a strut, and one that says sport, and another one that shows a fan with a radiator behind it... all of these didn't have lights in the socket from ford... anyone ever see them on theirs?
My guesses judging from my assorted Mondeos would be:
Pic of strut: never seen, I would suspect its something for the ride height adjustment (optional on Mondeos; to keep vehicle level with heavy load or trailer)
SPORT: ATX Sport mode (vs. economy); toggled by a switch on the shifter bezel.
Pic of fan w/ radiator: Low coolant warning light
HTH Joerg
Joerg
Posts: 1,040 |
Originally posted by J. Salvi: Does anyone have an instrument cluster (w/ tach) schematic for a 98+ Zetec cluster? I have one that I want to install but something on the speedo board is fried because when I attempted to install it the other day, smoke started coming from the connector. Do the cd-rom manuals come with detailed schematics? If so, could someone send me one via email? Thanks for your help! I advised this gentleman to post on this thread since I only have '97 manual and no scanner. Would appreciate any assistance from members that have done this mod. and have the info. Thanks.
Posts: 75 |
I want the rpm gauge on my dash as well. I have a 2000 SE (zetec), and my dash looks just like the first picture in this post, it just has the mph, gas, and temp. gauge. Where can I get the rpm gauge.. and from there y'all can teach me how to install it. Thank you.. My email is j_dawg1084@yahoo.com
Posts: 3,950 |
Originally posted by sleepie1084: I want the rpm gauge on my dash as well. I have a 2000 SE (zetec), and my dash looks just like the first picture in this post, it just has the mph, gas, and temp. gauge. Where can I get the rpm gauge.. and from there y'all can teach me how to install it. Thank you.. My email is j_dawg1084@yahoo.com If you have the 2000 chances are even if you get a tach it will not work. The newer Zetecs seem to be missing the tach signal wire. I am still in the process of making it work.
