Posts: 80 |
is the resonator, the thing that looks like a muffler, that is directly below the armrest in the car?
---------------------------------- '98 gl ATX K&N drop in filter, with gutted airbox, thanx to zetecracing, and hissvt2!! neon lights inside and out, xenon turn indicators, and lowbeams polk audio 5x7's, 2 rockford fosgate 75 watt tweeters, 300 watt Rockford Fosgates, 760 watt xplod amp, and head unit SE 15"s 'da bomb' style muffler, no resonator, duals coming soon!! more than you can afford pal... "Contour" my car... http://www.pbase.com/lokoros/inbox
Posts: 785 |
Red '97 GL Sport MTX IVELISE ================================== "Let every nation know, whether it wishes us well or ill, that we shall pay any price, bear any burden, meet any hardship, support any friend, oppose any foe to assure the survival and success of liberty." John F. Kennedy
Posts: 3,950 |
Posts: 494 |
Originally posted by Richard Edmonds: is the resonator, the thing that looks like a muffler, that is directly below the armrest in the car? I removed my armrest and I can't see the resonator! :rolleyes: Are you sure it is below your armrest? :p What year is your tour? LoL Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 1,692 |
that is the res.... remove it and put in straight pipe in there.
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 80 |
would there be 2 muffler like things below the car, because my friend that the thing we are looking at is the catalytic convertor. The thing I am looking at is almost directly below the armrest, and it looks just like a muffler. Oh and I have a 98gl, I will have some pictures of it up soon.
Posts: 669 |
no....your cat convertor is in the very front of your car.....behind the radiator running vertically next to the engine......you are right.....that is the res......the one in the middle of the car......hope that helps
-chris- 96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Posts: 139 |
I live in Fl and the Cat is no longer required. How hard would it be to replace from the res to the manifold. You have to cut the resonator out anyway and since I don't need the catalytic converter it only makes since to do them both. I guess my question is does the pipe really bend alot between those to points? I'm figuring that's where the real cost is, bending the pipe. Any ideas?
99 SE Zetec ATX CTA intake ZX2 FMS wires(that don't fit my oddball coil) andenthal@mindspring.com
Posts: 113 |
NO way is the Cat not required..check before you do it..empty it and just keep the shell
96 zetec gl.dynomax exhaust(self bent) KKM intake..Bridgestone Potenza RE-910's...other mods also 87' Ford Thunderbird..Now my daily driver ( the wife uses the contour mostly) true dual exhaust with the super mystery mod.(hey there not even there!) tinted windows and stereo upgrade. the $200 car is starting to be a great car
Posts: 139 |
They stopped doing emissions tests last year. It might be required but...
