Posts: 620 |
Chris: I went in for a smog check and asked if my CTA intake would be a problem; they said they'd reject it if I don't have a California Air Resources Board sticker verifying that it's legal for California. Do you have such stickers? If not, why not?
Failing that, I'll put the stock intake back on until the test is passed.
It might not be too easy to pass, because (as I've mentioned in Problems) my engine is not running right, and two days ago it threw a CEL with code 171, Too Lean. I tried injector cleaner and a new fuel filter. What else can cause a lean condition? A dirty MAF, maybe? Oxygen sensors?
By the way, the garage guy who looked at the intake called it a "nice piece".
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Master P
Master P
Posts: 5,455 |
Getting something certified by CARB is $$$$$$$. You'll find very few aftermarket parts with a CARB certification.
Posts: 2,523 |
Originally posted by Paul Kienitz: What else can cause a lean condition? A dirty MAF, maybe? Oxygen sensors?
I replaced my O2 sensor (upstream) to fix my problem and it didn't. Ended up cleaning the MAF sensor elements and that fixed it. Just be careful!!
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 8 |
D Davis, How do you clean the MAF elements? I have a lean condition also, (code 181), and the new o2 sensor didn't solve the problem for me either.
Posts: 1,202 |
Originally posted by Paul Kienitz: Chris: I went in for a smog check and asked if my CTA intake would be a problem; they said they'd reject it if I don't have a California Air Resources Board sticker verifying that it's legal for California. Do you have such stickers? If not, why not?
By the way, the garage guy who looked at the intake called it a "nice piece". Paul, as with many other manufacturers and after market shops like us, modification parts are deemed for off road use only. That leaves the responsibility to the end user. In the case of CARB, we are based out of Canada and are not seeking the CARB specification as per my previous statement. Technically speaking, our intakes can be made emissions legal, by routing the valve cover gases back to the intake tract (after 98 intakes) and using a semi enclosed heat shielded filter, with inlet connected to the fender opening. By golly, you may as well use a stock intake, if you know what I mean. Your CEL may be a bad O2 sensor. It starts out being an intermittent CEL then happens more often till it causes a solid CEL.
Posts: 620 |
Originally posted by cawong11:
Technically speaking, our intakes can be made emissions legal, by routing the valve cover gases back to the intake tract (after 98 intakes) and using a semi enclosed heat shielded filter, with inlet connected to the fender opening. By golly, you may as well use a stock intake, if you know what I mean. Now wait, my pre98 routes the gases back to the intake, and I do have a semi enclosed heat shield... and I don't think it's quite like going back to stock. So it probably could be certified if someone were to put up ten billion dollars in state fees...? I'm almost curious enough to pay someone to sniff the exhaust and see if the emissions are any different from stock.
Posts: 1,969 |
Paul- I just had my car sniffed in GA (not nearly as strict as CA) with the CTA on and based on the readings (.01 IIRC), you could barely tell my car was running Sniffer wise, I think you will be fine. Can't say about the visual. BTW- Chris, I can vouch for the emissions not being effected by the CTA Intake.
Kharma is very real and she is one mean b!tch.
Posts: 1,202 |
Originally posted by redhawk: Paul- I just had my car sniffed in GA (not nearly as strict as CA) with the CTA on and based on the readings (.01 IIRC), you could barely tell my car was running
BTW- Chris, I can vouch for the emissions not being effected by the CTA Intake.Thanks for the update, Matt.
Posts: 620 |
That's good to hear. I wouldn't want to be smogging the sky in my quest to get a little more go.
