Posts: 1,244 |
Sorry for posting this dead topic ya'll!!!!
Now I just have to decide what kind and weight to use with the FRAM oil filter. Many of you are running Mobil 1 Synthetic. My main concerns were oil leaks, engine wear, and the temperature of the engine(my engine runs on L all the time).
Posts: 364 |
Originally posted by Escort1991: Sorry for posting this dead topic ya'll!!!!
Now I just have to decide what kind and weight to use with the FRAM oil filter. Many of you are running Mobil 1 Synthetic. My main concerns were oil leaks, engine wear, and the temperature of the engine(my engine runs on L all the time). Change Filters?
2002 Mitsui Lancer-Black MTX.
Posts: 1,075 |
I'm running Mobil Tri-synth. 5w-30 with a motorcraft filter...haven't noticed much difference, but with only 38k on the car, I would hope I wouldn't...
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 620 |
Now I just have to decide what kind and weight to use with the FRAM oil filter. If you're insisting on FRAM quality, then you'd better use the cheapest oil you can find. If Mobil 1 is worthwhile, so is a decent filter...
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 1,559 |
Guys what Number of K&N Oil filter should I be using? I got the one the Advanced Auto Computer said but it's the wrong side thread(Too big). Thanks!
Posts: 1,969 |
I don't think K&N makes one for our cars but you could probably go with a PureOne from purolator
Kharma is very real and she is one mean b!tch.
Posts: 1,692 |
Originally posted by Lee Cox: Guys what Number of K&N Oil filter should I be using? I got the one the Advanced Auto Computer said but it's the wrong side thread(Too big). Thanks! that would be hp-2004 I have been using this since 1998 on my car.
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 1,692 |
Originally posted by redhawk: I don't think K&N makes one for our cars but you could probably go with a PureOne from purolator yes they do.... see my last post.
Posts: 1,244 |
Sorry fellas, a lot of people I know use the FRAM oil filter and the like it(but they also use dino). I didnt think it would make much of a difference, I guess you learn something new everyday.
Now another question is where can I find a Purolator PureOne oil filter?
TIA
Posts: 1,692 |
Originally posted by Escort1991: Now another question is where can I find a Purolator PureOne oil filter?
TIA Sears should have them they do by me. have you changed your oil on your zetec before??? if you haven't you will find it is MUCH easier with the K&N cause it has a nut on the end if the filter. I had broken 2 oil filter wrenches getting off the one that was on the car after I bought it. never had a problem with the K&N all I need is 1 scoket, 1 universial joint, and one ratchet.
