Page 3 of 4 1 2 3 4
#296021 02/15/02 07:48 PM
I also use 94 octane and I race all the time with no knocking or pinging! smile
I was thinking of putting in some Octane Boost also but if these engines are "fussy" with octane, I will leave the Octane Boost out of the tank! :rolleyes:
My guess would be that it is not fuel octane related. Perhaps the sensors/sendors as others have sugested!
I'd pull the temp gauge sender, and test it to see if it's reading low. Make sure the coolant temps aren't actually too high. I'd recheck static and ign timing also.
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
#296022 02/15/02 08:19 PM
Originally posted by redhawk:
I use high octance with no chip...
I don't think its pinging. What does it sound like when it does ping?
If it happens in warm weather and heavy engine load, it's definitely pinging, and dangerous.
Maybe check the rest of the EGR system. Make sure there isn't a pipe clogged with carbonized gunk or something. Maybe look inside the cylinder with a tiny mirror or something, see if it's clean in there. Plus whatever the other guys think up.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
#296023 02/15/02 08:34 PM
my zetec won't run on anything other than regular 87 octane. if i put ethanol in it, it runs like crap. never used premium. no need to in these engines. what you gonna gain, a little less vibration at idle while in drive? i doubt it. 30 mpg a tank and still sailin'. :p
i will always have a comeback! :o)
#296024 02/15/02 08:39 PM
BBorges Offline OP
But wouldnt I get a code for a bad sensor ???
confused confused confused
Someone once told me it could be the EGR.... but when i talked to people about EGR x Knocking they said they weren't related...
** CT - USA **
* 96 Contour Gl 2.0
5 Speed Manual / Clarion CD Change
8" Subwoofer & Sony Amp (LOUD !!)
The Cleanest !!!
* 92 Mazda Protege
5 Speed Manual / 1.8
* 94 Yamaha Virago 535
(better than Viagra !!)
#296025 02/15/02 09:13 PM
bborges...how old are your plugs/wires?????
Originally posted by fazzman:
Its called run the zetec into the wall and get a real car, thats my plan anyways. The zetec is a joke, i know that because i have one.
nick this makes a lot of sense :rolleyes:
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
#296026 02/15/02 09:57 PM
Originally posted by D Davis:
Maybe like popcorn popping? That's what Po-Jay's sounded like.
How loud is it? I don't think I've ever heard a car do it before...
Kharma is very real and she is one mean b!tch.
#296027 02/15/02 10:03 PM
BBorges Offline OP
Hey Corey !!
Checking the Zetecs now ???
wink wink wink
Planning to get the real thing ???
laugh laugh
I had the wires / plugs changed.. less than 10k...
About the popcorn sound... I was going to say that... but i thought that was very silly to say... but it does sound like that.. i mean... not exactly....
** CT - USA **
* 96 Contour Gl 2.0
The Cleanest !!!
* 92 Mazda Protege
#296028 02/15/02 10:04 PM
BBorges Offline OP
Anyone can confirm me the relation between EGR x Knocking ???
** CT - USA **
* 96 Contour Gl 2.0
The Cleanest !!!
* 92 Mazda Protege
#296029 02/15/02 11:24 PM
Not very loud, from what I know.
125.2 FWHP - 126.5 FWTQ
SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!)
Black '98.5 SE Zetec MTX
Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
#296030 02/15/02 11:41 PM
When I really run mine hard, it has that "popcorn"
sound, but it sounds like it comes from where the glovebox is, like behind it. Is that the same as what you all are talking about?? confused
-Ken V.
psycho_bass@hotmail.com
My Car
Page 3 of 4 1 2 3 4
