Posts: 956 |
You guys think the gas could be my problem ???
That's ironic... I only use the 93 gas because I was trying to avoid pinging....
I don't know what to do...
Hey JPet, it gets loud if I want to... u know.. If I really force it it gets loud... but I never do that... because it's dangerous...
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 3,165 |
WEll, if it was pinging and knocking before you went to 93, then more than likely it's not the gas, but if it started after you went to 93 octane, then that'd be my guess. If it's makeing wierd noises, don't force it! I don't want to see a "my zetec blew up" post
Posts: 1,692 |
Originally posted by fazzman: Its called run the zetec into the wall and get a real car, thats my plan anyways. The zetec is a joke, i know that because i have one. Next time but a MTX... they are alot more fun
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 1,692 |
and on the pinging.... I would think it is the gas mine seems to do that with 93 oct. no problems with 91 or 89 though run your tank almost dry and fill up with 87 or 89 and see if the problem is still there or try 91.
Posts: 85 |
My 96'Zetec has a similar problem. I read somewhere on a previous post that it only pings when the engine first starts out because the oil hasn't had a chance to do its thing yet(i forgot what the person refered to it as). It isn't a problem as long as you change your oil on its due date.When mine pings, it goes away within 2 minutes of easy driving.
Posts: 20 |
I take it that there are no codes being thrown... like for a bad knock sensor?A higher octane fuel gives a more even burn. I use a contour zetec with stock management on the 93 octane w/o detonation or preignition. I'd pull the temp gauge sender, and test it to see if it's reading low. Make sure the coolant temps aren't actually too high. I'd recheck static and ign timing also.
Posts: 1,969 |
I use high octance with no chip...
I don't think its pinging. What does it sound like when it does ping?
Kharma is very real and she is one mean b!tch.
Posts: 651 |
Originally posted by fazzman: Its called run the zetec into the wall and get a real car, thats my plan anyways. The zetec is a joke, i know that because i have one. :rolleyes:
99 SVT...modified 96 GL....the beater "I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
Posts: 956 |
Originally posted by redhawk:
I don't think its pinging. What does it sound like when it does ping? I don't know how to explain the sound.... Anyone ??
** CT - USA **
Posts: 2,523 |
Maybe like popcorn popping? That's what Po-Jay's sounded like.
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
