Page 2 of 7 1 2 3 4 5 6 7
Originally posted by tbunder:
redhawk, here's a tip. maybe try buying an actual performance car?
:rolleyes:
still want a four?
Yes, I do
maybe a hard core SE-R, both versions will smoke any zetec contique and most other cars in their class.
Aren't those only two doors?
maybe an svt focus,
Ugly
civic si, etc.
Uglier
if you want power and good mpg,
There is no such thing
you're in the wrong car my man. unless you have thousands to put into your crappy but reliable oil-starved zetec, it's a pooch any way you look at it.
Are you done?? Do you ever have anything useful to add to an arguement?? If you have please link me to it because I have yet to see it.
Brad
redhawk Offline OP
Thanks Brad.
He pretty much covered it tbunder.
But one question, do you ever get tired of being dumb? Because you certainly are good at it...
Kharma is very real and she is one mean b!tch.
Originally posted by redhawk:
Thanks Brad.
smile
I still haven't figured out if tbunder is trying to be a troll or not. Sometimes he posts actual questions/responses, and then other times he sounds like some of our more colorful trolls... confused
125.2 FWHP - 126.5 FWTQ
SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!)
Black '98.5 SE Zetec MTX
Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
N
N
wouldnt manualy shifting an ATX do no good for the tranny???
1996 Contour
New amp rack and custom box
pics coming soon
"When im good, im really good, but when Im bad, Im even better"
Easier to get a chip this is what I noticed: it shifts from 1st to 2nd at 35 at 6000rpm, 2nd to 3rd at 70 (6000rpm), 3rd to 4th at 110 and just keeps on going.
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Originally posted by Stephen:
The question I have is, does the ATX have an axel lock? I'm not sure if that is what you call it, but what I mean is when you get to a hwy speed does the power go straight from the engine to the wheels without any changes?
Yes, it has one. I think you can call it a torque converter lock. One thing that a chip does, I understand, is to make more aggressive use of this lock so the power is going straight through much more of the time. The stock tranny program avoids this in order to keep the acceleration smooth. I gather that the chip lets each shift give you a jolt just like a manual.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Well during hard acceleration it shifts fairly smooth. Every other time it can shift hard at times.
Hector
Mods...I got em'
My profile
[QUOTE] Paul Kienitz / Yes, it has one. I think you can call it a torque converter lock. One thing that a chip does, I understand, is to make more aggressive use of this lock so the power is going straight through much more of the time. The stock tranny program avoids this in order to keep the acceleration smooth. I gather that the chip lets each shift give you a jolt just like a manual.
[QUOTE]
The prior owner of my tour must have put a chip in then because when I'm racing, the trany shifts sharply and I do get os "jolt". Also the "torque converter lock" seems to come into play right when I need it! laugh
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
sqplus and redhawk- ME being dumb? better look in the mirror. an SE-R is a four-door sedan, dummy.
no such thing as performance and good mpg? Mark VIII-300 horses and 30 mpg. who's the dumb one now? eek
i will always have a comeback! :o)
