#295876 02/13/02 01:48 AM
jag Offline OP
Can a mechanical oil pressure gauge be used on the zetek or do i need to get the electrical one any help appreciated Thanks
97 GL Loaded
Alpine,JL,fosgate system
custom daul exhaust
OBX intake
intrax springs
flipflop trunk
tinted all the around
#295877 02/13/02 02:23 AM
Master P
Master P
Use electrical.
#295878 02/13/02 12:41 PM
I used mechanical. There is a blanked off second oil sender location about 3" to the rear of the used one
Mad Mole
Visit Mad Moles Mondeo Madness
2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc.
192 BHP, Faster than a speeding Duratec!
#295879 02/13/02 02:09 PM
You have two 1/4" NPT ports on the intake side of the block.
Unless you use a mechanical pressure gauge with threaded fittings, use an electrical gauge. The mech gauges with plastic/nylon capillary tubes are potential engine killers.
#295880 02/13/02 02:16 PM
jag Offline OP
might i ask why the ones with the plastic tubing may be engine killers just curious
97 GL Loaded
custom daul exhaust
OBX intake
intrax springs
flipflop trunk
#295881 02/13/02 02:27 PM
Mines copper piping (TIM) so its unlikely to melt like the plastic ones
Mad Mole
#295882 02/14/02 01:43 AM
If the plastic or the guage ever fails, your engine sprays its oil all over the ground, or in some cases, all over your leg. That's why manufacturers stopped including them.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
#295883 02/14/02 02:26 PM
I had to replace all bottom end bearings on my Zetec after a plastic oil pressure gauge split at the block fitting. Ironically I'd never trusted those with plastic lines, but I was holding off on replacing it till discretionary income was available. I'm now using one of those SPA oil temp/pressure combo gauges that also incorporates warning LEDs.At 5-6 bar, the sump is emptied very quickly.
For a mechanical app, do as Madmole recommends.
#295884 02/14/02 02:52 PM
What worried me is how low the oil pressure has to be before the Ford warning light comes on. Basically the damage is done way before it lights up
You guys who damaged your engine's were not obviously watching the oil pressure guage then wink wink
Just for info, when cold my oil pressure is 80 psi
when hot idle is 30psi and revs are 60psi
Hot is 80C on freeway, 90C town, max 100C in traffic (Oil cooler fitted)
Mad Mole
