Page 5 of 6 1 2 3 4 5 6
I went to a junkyard today and got a perfect cluster with only 60K on it, but alas, my 95 MTX is cable driven speedo, and the cluster I must be electronic because there is no inlet for a cable on the back. Oh well. I guess I will have to look for an older donor car. Is swapping the circuit boards ez? u are referring to the board inside the clusters, correct?
Thanks...
CURRENT RIDE: 95 GL
FORMER RIDE: 99 SVT (www.mysvt.com)
"You only live once, but if you lived my life, once would be enough." -Frank Sinatra
Joe,
Roger that...next time I'm there I'll check it out. You and JountourSVT might try working something out...sounds like he got a cluster he can't use...I'll bet you could use it.
Thanks...
Swapping the boards on my car(98.5) was easy, yes, on the earlier cars it might be a bigger problem. I've never looked so I can't say for sure. With my car the whole board comes off with three torx head bolts...thats it. If I can get a pic hosted I'll post the pics I took of the install up here. laugh
W
W
Originally posted by ZetecRacing:
you guys are the LUCKY few.... mine doesn't mad so I must say hello to an autometer tach soon laugh
That must be rough, MTX w/o a tach.
+Ford Thunderbird 1997 - V8
+Ford Contour 1995 GL [REST IN PEACE :(][Champagne|ATX]
-9mm Ford Racing wires
-CTA Intake Kit
-Removed exaust resonator
So is 1995 the only cable driven speedo year?
CURRENT RIDE: 95 GL
Lee Offline
No. It was changed part way in 96 I believe. There is a date for it.
Lee Cox
In life begins responsability...
Project Car
I found a cluster for $50 from a place a mile from my apt! Before buying it I need to know, can you swap odometers?
Mine is a '96 Contour GL, the new cluster is from a '95 Mystique. The new cluster has 135k, mine has 91k. Also, will I run into speedo cable issues?
96 Contour GL (2.0L Zetec, ATX)
Sony CDX-C780 HU, Sony CDX-805 10 disc Changer, Sony XDP-210EQ, RF Punch 100.2 Amp, RF Punch 240.4 Amp, Dual 12'' Punch subs, Four Infinity Kappa 693.3i 6x9's, Optima Yellow Top
CTA Intake, Hood Struts, EL Ford Logo, Hi Beam/Low Beam Mod, Blue LEDs in door handles and footwells
Z
Z
yes, those were the only ones that were OBD I 96 and newer were OBD II and were not cable driven.
Joe Hartley
"yes I know it's a MTX Zetec but it beats having a ATX Duratec"
Champagne 96 GL MTX some mods
dynoed at 114.2whp and 124.4wtq (pre CTA intake)
16.858 @ 80.76mph (yes it's slow but still faster than D Davis)
AIM: ZetecRacing
My Site My Profile
zetecracing-
ah, i see, thanks...
also, give me a few more days, if i dont hear back from the other guy, you get dibs on the cluster.
CURRENT RIDE: 95 GL
anyone else know of a cable drive cluster with tach, (mileage doesnt matter) for sale somewhere?
CURRENT RIDE: 95 GL
FWIW I have a tach cluster from a 96 Zetec. Lemme know what year you have. If you get a car with the same year you're allright.
HTH
John
jcaimhigher@hotmail.com
