I'm gonna guess you're talking to me? Well, here's the breakdown...
I'm assuming you know my car was running too lean. After basically forcing a B&M CommandFlo Pressure Regulator to fit the stock regulator in the Zetec, we managed to get pressure from 29 psi to 60. Well, after much advice and a CEL, we found that was too high, so we backed it to 45 psi. Haven't dynoed w/ the new setting, but at 60 I was pushing what's in my sig. The intake was on hold until we got that out of the way.
Tomorrow I'm going back to the dyno (my wife is starting to get angry
) to hopefully do a few passes w/ the current setup and w/ the intake. We have most of the bugs worked out and all we have to do now is get the length perfect. Which leads me to a few questions for you guys as possible consumers...
1) Is this is even something you're interested in? Keep in mind you have a fellow CEGer (actually 2 - Kaiser and myself) handing you the dyno info (I'm not getting anything from this but one of the intakes, so don't sweat that)
2) The current setup is running into the fenderwell and towards the ground (can't be too specific, yet). That means cutting of the fenderwell to allow room for it to pass. How many would be willing to do this?
3) If not willing to cut, would you be interested in a "short" version if we could prove dyno gains?
4) Would you prefer the kit be offered with a filter, without or both? Any particular filter you'd like to see?
5) Is color an issue? I don't know if colors will be optional, but if you'd like blue pipes, for instance, I can pass it along.
I'm just as anxious as you guys are regarding seeing a finished product. I want this under my hood. Also, I can't do anymore mods until we're through with R&D (can't risk botching the #s), which is driving me nuts. I want my damn exhaust hung!!!!
