#294634 12/08/01 11:01 AM
LoCo Offline OP
I just wanted to know what was the throttle body size for the Zetec Contour and if they made any aftermarket throttle body and MAF?
Thx
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
#294635 12/08/01 04:33 PM
Master P
Master P
57mm, never seen an aftermarket TB, cept for the Focus, and that prolly won't work. SP sells a MAF for the Focus that should work.
#294636 12/08/01 04:40 PM
SP told me the MAF probably won't work. Crossed part #"s with buddies 01 Focus same # so its worth checking out first
'69 Chevelle SS
'99 Mystaque GS
#294637 12/08/01 05:59 PM
man tb's have been pulled of stangs and put on civics..its some tb that has to fit
ZTEC..Custom Abs Intake. 2 1/4 Catback Exaust (No Res)..Accel Coil, Accel Wires,Magnaflow muffler,Clear Corners,Removed Ding Guards..Fuel Cutoff Disable Switch,blue)...Headers,Turbo,Neon Underbody lights comming soon
#294638 12/08/01 06:28 PM
the focus bbk looks real close to my 99 but?
'69 Chevelle SS
'99 Mystaque GS
#294639 12/24/01 09:24 PM
Focus Central has a 65mm TB for $250. Pretty pricey considering that no-one knows if it will work or not.
Also, Sport Compact Car Magazine was fixing up a Focus using the BBK throttle body. If the Focus Zetec TB and the Contour TB are interchangable, the BBK should work. I can't seem to find the BBK Focus Throttle Body anywhere, even on their website. Has anyone had any luck?
96 Contour GL (2.0L Zetec, ATX)
Sony CDX-C780 HU, Sony CDX-805 10 disc Changer, Sony XDP-210EQ, RF Punch 100.2 Amp, RF Punch 240.4 Amp, Dual 12'' Punch subs, Four Infinity Kappa 693.3i 6x9's, Optima Yellow Top
CTA Intake, Hood Struts, EL Ford Logo, Hi Beam/Low Beam Mod, Blue LEDs in door handles and footwells
#294640 12/24/01 10:02 PM
That won't fit. I built a new plate for Darrel's induction kit already so I am fairly familiar with the tb. I'd be willing to bore one out, put in a new plate and dyno it if there was some interest.
If it's true that we are here to help others, then what exactly are the others here for?
#294641 12/27/01 05:29 AM
Which one won't fit, the BBK, the Focus Central, or both? What is different? Mounting holes, size, height, etc?
Thanks in advance for the info.
#294642 12/28/01 06:31 AM
The stock TB for the Contour Zetec was 55 mm. The critical dimension you want to measure is the throttle plate diameter. The Zetec in the ZX2 and the Contour use similar intake manifolds. The Gude 58 mm TB for the ZX2 Zetec should bolt right on with some minor grinding needed to port matech the TB to the manifold.
The image below shows a modified 1996 'Tour 55 mm TB which was bored and polished to take a 57.6 mm throttle plate. Air flow measured on a flow bench was ~18% higher than stock at equivalent pressure drop. I have this one mounted on a 2000 ZX2 S/R.
57.6 mm Zetec throttle body
#294643 12/28/01 06:09 PM
IIRC the SE v6 is 55 and the zetec is already 57?
