Page 2 of 2 1 2
#294553 12/03/01 01:02 AM
Ok. well eerything that is connected to the coil is tight and in place.
Tony
1999 Contour SE 2.0L VCT
Mods:
*BFGoodrich P195/65R14
*Pioneer 3100 Cd player
*Pioneer 6'x8' 3-ways
*2 12' Super Blue Subs
*Pyramid 400 Watt Amp
*Yellow Fog Lights
*Magnaflow Exhaust #14822
#294554 12/03/01 01:18 AM
Master P
Master P
Can you hear the fuel pump running before you try to crank it? Is the check engine light off while you crank?
Jim Johnson just made a nice post to the mailing list about a problem he was having, those were a couple symptoms he was describing.
Here's the message. Give that a read and see if it helps out: http://www.coldair.org/archives/0112/msg00010.html
#294555 12/05/01 10:35 AM
E
E
Mine was just the opposite. Everything would power up, but the car wouldn't crank. I thought I tested everything, so tonite I bought a circuit breaker so I could see if I could find the break in the wire (I had a wire melt). I put the breaker in where the 20A igntion fuse is in the power block. I got in, unwired all the wires I had used to hotwire the car, turned the key and it started. I didn't know if I should be happy or pissed. It took me four days of tinkering with it, and it was a bad fuse, that I thought I had tested.
On the bright side, I got the dashboard dyed black while I was at it. smile
Anyway, to make a long story short, CHECK EVERY FUSE!
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#294556 12/05/01 08:37 PM
Found out what the problem was. It was the fuel pump. I got it back but the place i took it didnt look to find out that the gas gauge wasnt reading, so i took it back again this morning and they are fixing the wires.
Tony
Mods:
*Yellow Fog Lights
#294557 12/07/01 06:53 AM
That happened to me with my previous junker: bad heater blower fuse, which I swore I had checked.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Page 2 of 2 1 2
