Posts: 15 |
I got a GL Zetec Sport with a tach
1st 34 @ 6500 2nd 55 @ 6500 3rd 81 @ 6500 4th 110 @ 6100 5th the govener wont let me find out
I found this out with a bad O2 sensor. The lower speeds are off by one or two cause I go through them so quick. But 3rd and 4th are positive. If you don't have a tach i won't recommend it.
97 Contour GL MTX K&N Intake Artic White Lights Blue Stobes Kenwood KRC-508S head unit Kenwood KDC-D300 11 Band Spectrum Analyzer CD Player MTX RT-2120 12" Polk EX
Posts: 2,523 |
Just a note:
If the theory holds true that your speed in 4th gear @ 2750 (half of 5500) can be doubled to give you the approx. speed at 5500 rpm, I'd wager to bet 4th gear @ 5500 should equate to ~103 mph - 51-52 was indicated by my tach at 2750 in 4th. No good chance to actually hit 5500 recently.
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 761 |
Hey millhouse, is your MTX or ATX? Mine is ATX and I have a tach, we can get together and find out
Posts: 51 |
What do mean? Do you wanna run one?  I too have an atx. You must have the sport option right? Or did you intall aftermarket or oem gauges?
Posts: 3,774 |
i don't think you needed the sport option to get the tach. if you got the "power package" which included power windows and doors, you also got a tach, but no foglights.
if you got a sunroof, they would through in a tach.
the packaging system made absolutley no sense in those days. and why they would make a manual transmission car without a tach is beyond me. without a speedometer i could understand, but a tach? so you're assuming that the non-performance oriented person purchasing the car would have enough knowledge of where to shift just by 'listening' for the shift points. com'on Ford...get real!!!
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 761 |
Mine is a Mystique GS...factory. We live pretty close by, remember? (I live off 67)
Posts: 586 |
96 gl zetec all power...
no tach
1996 Contour GL
Posts: 51 |
I have a sliding sunroof, although it's not factory. It broke on me one day while it was open(I was going 75mph on the freeway), and it flew off into the stratosphere. I got lucky, because it's not a factory sunroof. A factory replacement glass was around 400$, and I got mine for 89$.
Posts: 956 |
Originally posted by contourgl_96: 96 gl zetec all power...
no tach Same here.... and no TACH
** CT - USA **
* 96 Contour Gl 2.0 5 Speed Manual / Clarion CD Change 8" Subwoofer & Sony Amp (LOUD !!) The Cleanest !!!
* 92 Mazda Protege 5 Speed Manual / 1.8
* 94 Yamaha Virago 535 (better than Viagra !!)
Posts: 620 |
Originally posted by baco99: i don't think you needed the sport option to get the tach. if you got the "power package" which included power windows and doors, you also got a tach, but no foglights.
the packaging system made absolutley no sense in those days. and why they would make a manual transmission car without a tach is beyond me. without a speedometer i could understand, but a tach? so you're assuming that the non-performance oriented person purchasing the car would have enough knowledge of where to shift just by 'listening' for the shift points. com'on Ford...get real!!! I have power windows etc without a tach... maybe they didn't bundle them together for atxes. As for hearing shift points, I think most stick drivers do pretty well with it by ear, even if they don't have perfect pitch, like I have. (middle A = 6600 RPM for a 4 cyl)
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
