Page 4 of 4 1 2 3 4
#294511 12/13/01 12:24 PM
I shift mostly by feel. I also use my hearing as reference, but it turns out that I have one or more bad wheel bearings, so hearing the motor can be a little tricky at times.
#294512 12/13/01 09:20 PM
Z
Z
my car is a 99 Cougar, I don't know if it is the same tranny....but there is a rev-limiter at 7200 rpm's. The max HP is at 5500. When racing, I usually shift at about 6000, then hold 3rd out to about 6500. Don't get to run 4th up as high usually.
Mark
'99 Black Cougar
#294513 12/14/01 12:32 AM
N
N
If u give me the following information i will tell u everything u want to know.
exact displacement
location of engine
type of engine
Max HP ? at ? rpm
Max Torque ? at ? rpm
Comp Ratio
Redline
Start RPM ? with clutch ?
Transmission ? speed ? type
Gear ratios 1-whatever amount of gears
Final drive ratio
Driving wheels
Weight
% of weight on front wheels
Wheel base
tire section width
Wheel diameter
Tire profile
Coeffient of drag
overall height, width
Ground Clearance
i can tell u anything u want performence wise about a care if u give me those things.
Experience is the worst teacher; it gives the test before presenting the lesson.
"You peel my onion down to the nun" - Gene Hackman [Under Suspicion]
-Walter-
96 Contour LX
Page 4 of 4 1 2 3 4
