Posts: 314 |
I'm writing this post with a few questions about the shifter mod, could you please help.
How much did you cut off the length of the shifter rod? Is it the same diameter all the way down or did you cut it off short of any taper or is it too shallow of a taper to worry about? What thread is the die (I'll need to borrow one from work)? How extensive is it to rip apart the whole thing (how much time will it add to the mod)? What grease is recommended to re-lube the shifter/assembly?
Thank-you.
Black 98' Merc Stique GS MTX Duratec
Cat-back 2.5" SS plumbing with Flowmaster 40 muffler KKM True Rev induction Eibach Lowering Springs 16" Fast 17 wheels with 225/50/16 Potenza RE910's Code alarm with pager 20% tint on sides and 5% on back Alpena Racing pedals Painted calipers (black) 55W & 65W Xenon Headlamps Mobil 1 Synthetic ATF with Ford FM Clear Side Markers w/orange bulbs Removed rear badging
"Park it, or put a porch on it!"
Posts: 743 |
i have a question to add to this..will the throw be any shorter or is it just for looks?
Posts: 716 |
I we cut mine off about 1.5 inches, Sparks said he originally cut his MUCH shorter. The rod is the same diameter all the way down. We didn't rethread mine, just put a Momo AirLeather knob on it (which has a set screw), it took Shaun all of 5 minutes to have the shifter out of the car and on a table, about 10 minutes to take it apart on the table and regrease, using White Lithium Grease. Any other questions? -Chris
Chris Hinds AIM:CJ111010 1998 Contour GL Duratec 5-Spd #565/???? 15.610 @ 89.62mph And I payed for it all myself
Posts: 4,319 |
I have a question! When the hell are you gonna vacuum that thing!!!!!!
1991 GVR4 Lots of mods done.
Posts: 4,319 |
Golof, it changes the throw in essence, but it still has the same feel of the stock shifter. The geometry remains the same, therefore the shift only "feels" different. If you have a chance, once cut you shifter, try to find someone with the B&M. You will "feel" a huge difference
Posts: 1,428 |
Originally posted by Not Jap: I...What thread is the die... Thread is M12 x 1.25 ... Not common AT ALL. As said by others, I does shorten the throws some, nothing like a B&M though, as you're not lenghtening (sp?) the lower part of the rod. Sure helps in taking that 1988 Tercel look out of the shifter tho!
Posts: 716 |
Originally posted by T-RedSVT: I have a question! When the hell are you gonna vacuum that thing!!!!!! Friday mi amigo.. -Chris
Posts: 743 |
Originally posted by T-RedSVT: Golof, it changes the throw in essence, but it still has the same feel of the stock shifter. The geometry remains the same, therefore the shift only "feels" different. If you have a chance, once cut you shifter, try to find someone with the B&M. You will "feel" a huge difference cant! 95...it sucks...i want to try and make a short shifter tho
Posts: 314 |
Thanks guys!
Posts: 446 |
I don't need to add anything, they covered it
