Posts: 20 |
What is it 2" or 2.25" please don,t make me go outside and measure. It's cold out there. Oh yeah and I was reading the Nov. issue of Sport Compact Car the wrench report, pipe diameter guidlines for building your own exhaust system were as follows: 1,500cc-2,000cc engines = 2" piping 2,100cc-2,500cc engines = 2.25" and so on and so forth. what is a cc, and How many cc is the 2.0L Zetec? by chance is it 1999cc? I need help. Magnaflows website only shows them having mandrel bent piping in 2.5" and 3" diameters anyway. :rolleyes:
97 Ford Contour GL ATX 2.0L Zetec. -KKM intake -Tube behind MAF from 98 -Spraypainted grill silver -SE spoiler -Removed resonator muffler -Wrecked -Sold to Carmax
96 Jeep Cherokee Country ATX 4.0L I6 4x2. -K&N FIPK cold air intake -Jardine cat back exhaust -APC halogen H-4 diamond series headlights w/sylvania cool blues 99 Dodge Avenger Sport ATX 2.5L V6. -K&N drop in air filter -http://www.Asog.net/ Sort of like Contour.org but for Avenger fans.
Posts: 20 |
Oh and somebody rate me please. Do I even get to see my own rating. Whats up with that!?
Posts: 2,246 |
If I recall correctly, the tubing is 2" to the cat, and after the cat it changes to 1.75". I am currently running the SVT exhaust which is 2" catback then split to 2.25" piping when it branches out as duals. (I think those are the right demensions)
As for the engine size,1L = ~1000cc, so 1999cc sounds about right. You should be fine up to about 2.25" piping all the way through. Anything more than that would probably cause a decrease in performance.
HTH
David Litsky AIM: DaveL225 My Car
Posts: 1,268 |
5 stars for Ted. My good deed for the day!
-Ken V. psycho_bass@hotmail.com My Car
Posts: 9,178 |
Posts: 1,969 |
Magnaflow make resonators and mufflers that will fit a 2" pipe fine but I think the diameter is 2" all the way after the cat???
Where's perry?
Kharma is very real and she is one mean b!tch.
Posts: 20 |
Thanx yall for the info. CRZYDRVR you rock!
Posts: 669 |
well i just ordered 2 new mufflers and a res from magnaflow and they are all 2.25, so i hope something will be worked when i put them on the car!!!!!!!!!!!
-chris- 96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Posts: 2,657 |
Originally posted by David L: If I recall correctly, the tubing is 2" to the cat, and after the cat it changes to 1.75". I am currently running the SVT exhaust which is 2" catback then split to 2.25" piping when it branches out as duals. (I think those are the right demensions)
Almost...your dimensions are backwards. Its 2.25 CAT back then splits to 2" in front of the gas tank.
