#294184 11/12/01 07:46 AM
O
O
Does anyone know the exact displacement of the Zetec engine? I have seen various #'s. My chilton's maual says 1999cc, Kragen.com and Carparts.com have their own figures, and when I entered the bore and stoke specs(from chiltons manual) into the equation for Displacement it gave me 1987.5cc. So what is it, I need to know! I have some very nice mods in the works wink and I need precise data going into them. Thanks.
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper)
Suffice it to say my mod list has become so long that it is just ridiculous
#294185 11/12/01 02:36 PM
You're referring to engine size, not displacement.
All US zetecs have 2.0 L displacement.
The size may vary by year by I don't know if it is as large as 1800cc.
Kharma is very real and she is one mean b!tch.
#294186 11/12/01 04:24 PM
1986cc is a number I run across frequently. Your manual should say something about it somewhere (probably in the back)
125.2 FWHP - 126.5 FWTQ
SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!)
Black '98.5 SE Zetec MTX
Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
#294187 11/12/01 04:28 PM
X
X
I have seen both 1999cc and 2000cc listed as displacement. Not sure if some years pistons are dished or domed which would make diffrences in displacement.
By the way redhawk, a gasoline engines size is usually refered to by its displacement, as apposed to its physical size or horsepower rating. And 1999cc's + 1.999L...ya need to buff up on the metric system a little bit wink
#294188 11/12/01 04:52 PM
Sorry if it was confusing but for most of us non-SAE certified guys, you hear displacement referred to and engine size as two different numbers.
#294189 11/12/01 09:45 PM
O
O
I am in need of an accurate #, be it by model year or whatever. Thanks.
#294190 11/12/01 09:54 PM
Master P
Master P
Look there towards the bottom right. Says 1988cc.
Same here .
If your mods are so sensitive that a few CC's will make a big difference, I'd suggest taking the engine apart and actually measuring things by hand.
#294191 11/12/01 10:27 PM
O
O
Perry, thanks for the info, but these are specs of zetecs outsided the US. Before everyone gets there flame throwers out about them being "exactly the same" let me just say: thats crap. The US spec Zetec has less HP due to it's Lower CR 9.6:1 V/S the Euro/Aussie spec Zetec with 10:1. If the CR is different it is highly likely there is a difference in thier displacement. Be it 11cc or 1.
#294192 11/12/01 10:46 PM
Master P
Master P
http://carpoint.msn.com/Vip/Engines/Ford/Contour/1996.asp (1996 Zetec -- 3.34 x 3.46... do the math, what do you get?)
Here's a few more pages w/ Zetec specs...
http://www.uscaterham.com/zetec.html
http://www.rmsci.com/engines.html
http://www.fordhaven.com/specs/2001_escape_1.html (that's for the 2001 Escape... still the exact same bore x stroke)
http://www.focaljet.com/5_resources/5_01-specs.htm
http://www.sportcompactcarweb.com/archives/features/feature03_0601.jsp (SVT Focus even uses the same bore x stroke)
Are you convinced?
P.S. Thanks Google !
#294193 11/17/01 12:19 AM
Probably not, actually... a different head would affect the compression, but would not affect the bore x stroke. To do that you'd need either a different block & pistons, or a different crankshaft & rods. I don't think anybody's changed those.
But then, off the top of my head I seem to remember a figure closer to 1950cc than to 1990...
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
