Page 2 of 2 1 2
Originally posted by xraymongral:
Now if I can only find a piece of steel .2" thick to make the cam locking tool.
There are two ways to go on that. Getting the tool from Ford is not one of them. Ford charges like $80 and makes you wait a month.
What we did for my engine was just take a chunk of flat .25" steel and mill it down to .2" with a drill press -- it wasn't pretty but with care it can be kept accurate enough by checking your work with a micrometer.
The other thing you could try is to just stack up some blocks and feelers to add up to a total of .2".
As mentioned, this is for alignment only -- not for bracing it to undo the gear bolts.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
tiv Offline
Where can I buy, or find info on how to make, a cam locking tool? I need to do the timing belt, and looks like I need this tool to make life easier. Does this tool work in conjunction with the camshaft pullys? If so, can I get away without removing the valve cover?
Only for the historians:
I (with a help of a mechanic friend) did mines without the tool (and removing the camshaft cover), just by marking the sprockets together with paint.
They moved about 1/8 rotation when we removed the belt (by valve springs I guess), we turned them back by hand and put on the
new belt.
It worked (I did some 20k miles since then), so I say you can do it without the aligning tool, but next time I wouldn't try without it, esp. if you're doing it alone.
Much less trouble and much more peace of mind smile
Tivadar
Page 2 of 2 1 2
