Posts: 2,246 |
Ok, are they for two completely different directions when it comes to performance? I am not too sure, just curious.
David Litsky AIM: DaveL225 My Car
Posts: 5,805 |
Headers,if designed correctly,should assist the 'extractor' effect by using the the firing cylinder 'pluses' to give a depression in the primary pipe just before the next cylinder exhausts,improving the 'scavange' improves the cylinder filling.A tubo does not want 'pulses',it needs a smooth flow of gas into and past the turbine blades to maintain speed.
Posts: 2,246 |
Originally posted by Terry Haines: Headers,if designed correctly,should assist the 'extractor' effect by using the the firing cylinder 'pluses' to give a depression in the primary pipe just before the next cylinder exhausts,improving the 'scavange' improves the cylinder filling.A tubo does not want 'pulses',it needs a smooth flow of gas into and past the turbine blades to maintain speed. Thanks for the insight Terry. I guess I will wait until the headers are developed to make a decision if I want to go all motor, or forced induction
Posts: 620 |
A tubo does not want 'pulses',it needs a smooth flow of gas into and past the turbine blades to maintain speed. Prediction: the hybrid electric car of the future will use an exhaust turbine to run a second electric generator. If you think that's funky... check out this . That could be the alternative.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth " mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip involuntary mods: compression increased after head gasket failure
Posts: 753 |
i heard something about 4-1 headers are better for top end and that 4-2-1 headers being better for low end torque, which our cars need badly. wouldn't it make more sense to go that route? any truth to this?
No car anymore ;\ (taking a break from driving due to several misfortunate occurances) Newest mod for my Dad's Cobra 'vert: My beautiful girlfriend and I for passengers when we want to go somewhere
Posts: 5,805 |
Depending on state of tune there are two types of header design.Either for 'independance' or 'interference' of engine pulses to aid extractor effect.Rembember headers are like camshafts,they are a compromise and only operate within certian rev ranges to give optimum power etc...as a cam.
Posts: 753 |
in layman's terms?
Posts: 5,805 |
4 to 1 is best for all round performance.As you increase the size/dia of the primary pipe you move the max torque further up the rpm range,it does not increase it just moves it to higher rpm.Example a 16V 2.0 dohc 'motor' in comp trim may make the 7000-9200 rpm range with primarys of say 2"OD and 28-30" long,for road use that same engine will only need 1 3/4" OD @ 38" long.Always rembember that with headers,whats gained at the top is lost at the bottom and vice-versa......
Posts: 753 |
so you're saying a 4 into 1 won't improve low end anything, it will make it worse and only increase top end?
Posts: 5,805 |
No,I said to move the torque peak up the rev range you need bigger dia primarys that are shorter.To have the torque at the lower end of the rev range you need smaller dia primaries that are longer...check the 'example' dimensions I've given.
