Page 1 of 4 1 2 3 4
#29383 05/16/01 04:37 PM
KJ Offline OP
I would like to know how long it takes and if anyone has gotten the Kit from SPMotorsports (from anywhere doesn't matter)? I am thinking about doing this while my EEC is getting worked on.
Married the gal of my dreams 04.27.02 smile
2K SVT Black/Midnight Blue
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
Best Time 14.942 at 93.98mph
Car is now for sale - 14000
#29384 05/16/01 04:54 PM
It took my 5 hours to do. Of course I ran the power wire inside the car instead of underneath. Pain in the ass to do.
1999 Silver Frost SVT
#2412 of 2760
DOB - 7/30/99
MODS:
BAT Inlet Pipe /w Monster Flow Filter, Rear Strut Brace, H&R Sport Springs, Koni Sport Struts, Panasonic CPQ-DF800u, Baer Brake Kit, Brembo Slotted/Crossdrilled rotors for rear brakes, rear KVR Pads, ASA JS6 17" w/ S-02 Pole Position, B&M Shifter, 22mm Rear Sway bar, Bassani Exhaust. SoundStream Rubicon 604 Amp, 2 SoundStream Class A 5.2 Amps, 2 SoundStream SPL 12" Subs, SoundStream SVX2 Crossover, Rockford Fosgate Capacitor.
#29385 05/16/01 05:38 PM
1
1
Why would they recommend running the wires outside?!
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
#29386 05/16/01 06:24 PM
F
F
Took me about 2 hours. I ran it under the car. I got the kit from Summit Racing, about $50. Its not a sealed box, so you should get a sealed battery.
Speed kills, but it beats going slow!
Simon Langley
Black 98 SVT EO (#2119 of 6535)
269.3 FWHP, 195.4 TQ
14.123 @ 97.36
All go, and no show!
Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust.
CDW-27 1/4 Mile Registry
#29387 05/21/01 03:37 AM
V
V
Hey guys what gauge wiring did you use? I have a custom intake coming (buddy's a machinist) so I want to remove the battery and place it in the trunk.
And where did you locate the box in the trunk..back right...front left?
Thanks for any info.
Alex
95 GL V6 MTX...was bone stock
#29388 05/21/01 09:27 PM
F
F
If you buy a kit, it will come with the wire, and everything else needed to do it. I'm not sure what the gauge of it is. I put it in the passenger side of the trunk, because my fat butt is sitting on the drivers side laugh
Simon Langley
14.123 @ 97.36
#29389 05/22/01 12:35 AM
H
H
Most kits have 2ga cable. That should be sufficient. Rod K.
Rod K.
98.5 SVT Contour E1 #5782
15.50 @ 88.92 frown
93 Lightning #1529
13.27 @ 101.55 on motor.
12.52 @ 107.28 on 125 shot.
#29390 05/22/01 08:28 PM
V
V
thanks for the info...
Once again this forum has proved to be a bountiful source of good and knowledgable people with lots of information to share...
wink
#29391 05/23/01 12:09 PM
Don't waste the money on a kit. You can buy the same battery box @ Autozone for 10 bucks (it's not that impressive anyway and I couldn't use half the stuff that came with the kit). All the connections you can get at Autozone or Home Depot. The wire is only 2 ga. in kits and very stiff. I went and bought 1 ga. welder's cable at a welder's supply. It's a little more expensive, but more cunductors (the more wires = more surface area of wire - the electrons travel on the surface of wire, so this is advantageous) and softer or more bendable). I then went and got some clear plastic tubing at Home Depot and slid it over the cable (with the help of some vegetable oil as lubricant). This tubing added protection since I decided to run the cable underneath the car. I used existing drain plugs (in spare tire depression for positive and trunk for ground) to go from the trunk to the engine bay and cable tied the cable to the fuel lines going forward. As far as croosing the engine bay, I just brought it up and across right at the cowl and on around to where the battery was. I used a gray PVC box from Home Depot that has a screw down lid and had all my cables go into it and made all my connections inside of the box. About 5 hours start to finish. Can get picts if you'd like.
Seth
sadams@recaro-nao.com
Custom Recaro Seats, B&M, Battery Relocation
http://www.svtoa-semi.com
#29392 05/23/01 02:25 PM
1
1
Actually, the more area also meeans more resistance which is not good because it'll have more voltage drop.
Car Pics
Page 1 of 4 1 2 3 4
