Page 2 of 3 1 2 3
#293705 10/25/01 07:15 PM
Its not strange considering that every magazine that tested it has the top speed listed at 105(governed). Also ford has a reputation of over restraining its most enjoyable cars. Thunderbirds(104),Focus(107)
98 Contour SE Zetec ATX
"Chevy Corsicas Fear me!"
"There's no such thing as a PRETTY GOOD alligator wrestler"
#293706 10/25/01 08:01 PM
Perhaps they're measuring true top speed, where we're just stating indicated speed. I could see an inaccuracy of about 3 mph or so at that speed...
Naw...that doesn't make any sense, either.
125.2 FWHP - 126.5 FWTQ
SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!)
Black '98.5 SE Zetec MTX
Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
#293707 10/26/01 01:47 AM
B Offline
i hit my govenor at 110 with my mtx. But I also hit fuel cutt off when i tried to push it past it.
97 Contour GL MTX
K&N Intake
Artic White Lights
Blue Stobes
Kenwood KRC-508S head unit
Kenwood KDC-D300 11 Band Spectrum
Analyzer CD Player
MTX RT-2120
12" Polk EX
#293708 10/26/01 03:31 AM
It was my understanding that the cutoff is supposed to hit at 112. In mine it happens at an indicated 110. I think what's happening is that your speedometer is reading lower than most of ours do. Whether the actual speed is 105 or 110 I don't know.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
#293709 10/26/01 03:38 AM
Master P
Master P
112 would make more sense (and is a number that I can remember being tossed around a couple years ago), because 205/60-R15 would be 2.0% too slow compared to 185/70-14.. So an indicated 110mph would be a hair above 112.
#293710 10/26/01 04:38 AM
I hit 180kph a couple of times myself. I believe that number is the equivelent to 112mph. What I would like to know is what would the zetecs top speed be drag limited!
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
#293711 10/26/01 01:08 PM
Could different years have different cutoffs programmed into the computer? I know that Dodge Stratus will do 125 in 98 but 99's only go 111 (V6)
#293712 10/26/01 01:10 PM
Also I am told that the faster you go the more inaccurate the speedo is (in most cases)
#293713 10/26/01 02:03 PM
Don't know about the rest of you but I've
got the 250/60/15 tires on my car and I had it recalibrated a while back. I testet it with my gps and there was only a mile difference in speed readings throughout the range of speed. My little Z'
cut off right at 110 on speedo and 111.7
reading on the gps. I'd say it's closer to 112 then.
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
#293714 10/27/01 08:34 AM
I'm not even going to get into the who top speed thing. Mine was 120mph, I have a chip and it was on the stock rims and tires.
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Page 2 of 3 1 2 3
