Page 3 of 3 1 2 3
#293715 10/27/01 08:13 PM
Originally posted by mbb41:
I hit 180kph a couple of times myself. I believe that number is the equivelent to 112mph. What I would like to know is what would the zetecs top speed be drag limited!
Around 135MPH (for a UK Mondeo Zetec with no speed limiter). Depends on the gearing and fuel quality etc, plus maybe other factors like external temperature.
Paul.
'93 16V Mondeo saloon
Full factory RS setup lowered on 17s
K+N 57i, splitfire leads, chipped, full aluminised twin-exit exhaust
Sounds by Alpine, Infinity, Vibe, JBL
First Mondeo with indiglo gauges
#293716 10/27/01 10:49 PM
yeah, Typhoons suck real bad with the governing chip. The thing is still zipping through 4th when BANG as soon as it hits 124 the fuel line cuts out. Hopefully a nice aftermarket chip will take care of that.
#293717 10/28/01 04:38 AM
9
9
i remember reading somewhere that the tours are limitied due to ****ty tires with low speed ratings but the cougars arn't
they said the 4 banger (zetec) cougar will go about 120 125mph and the v6 (duratec) cougar will go around 140mph
they also said the speed limiters spoiled the cars. and it does spoil the car
able to hit the limiter in 4th gear with so much room left in it is very disapointing
speed is adictive, the faster you go the more you want.
#293718 10/28/01 11:32 PM
Stock, with ATX, mine had nothing left when it reached the limiter. (It was a hot day the only time I did this.) But the CTA intake is on order, and other mods will come...
(Hey Chris, where are my brake rotors?)
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
#293719 10/29/01 06:45 AM
[QUOTE]Originally posted by Paul Kienitz:
[QB]
Mine is still pulling hard at 180 so I'm sure there is still room to play. I have an MTX so I wonder what difference that would make
confused
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Page 3 of 3 1 2 3
