Posts: 569 |
Has any one had a chance to dyno the CTA Intake yet, Hint Hint CTA.
**Spelling should not count**
2000 SE Zetec ATX Medium Steel Blue (Now with large custom dent on the rear door) Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Posts: 2,657 |
They have a dyno on there site from a zx2 that was equiped with a similar intake, you'll net similar gains as the zx2.
Posts: 569 |
Thanks, those are some respectable gains 8-10HP.
Posts: 974 |
Will the car not need a better flowing exhaust. If more air goes in, more has to be able to come out. I thought....
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
Posts: 569 |
Originally posted by crank: Will the car not need a better flowing exhaust. If more air goes in, more has to be able to come out. I thought....  Yeah thats true, But more air in only will still return a positive increase in HP. Adding exhaust after that will probably add another 8-10HP
Posts: 2,657 |
True, you do need a higher flowing exhaust to get the full benefit of that intake. But you can install it on a stock engine and still see gains. I'm pretty sure that zx2 had an accel coil and a different muffler. So, I doubt you'll see the gains they did if you install it on a stock engine.
Posts: 1,202 |
Originally posted by SQPlus: True, you do need a higher flowing exhaust to get the full benefit of that intake. But you can install it on a stock engine and still see gains. I'm pretty sure that zx2 had an accel coil and a different muffler. So, I doubt you'll see the gains they did if you install it on a stock engine.  The ZX2 that was tested was all stock except the coil and wires. The ignition gains almost nothing so most of the gains on that vehicle were from the intake kit. The exhaust was stock too.
Posts: 569 |
The dyno plot said Accel Coil Pack, Magnacore, CTA Intake. 10 HP gain 8 lb torque gain I'd say those real numbers, in that we would see the same gains.
Posts: 569 |
CTA people, do you have any exhaust systems for a zetec Contour, the Exhaust page says all contours. But it just doesn't look like it will fit.
If not what would the odds of a ZX2 or focus cat back bolting on.
Posts: 2,657 |
Thats why Chris is here...I wasn't sure about the exhaust, now we know. I guess I'm just too lazy to go and look at the dyno.
