#292630 08/08/01 07:52 PM
PeterH Offline OP
Is there any upgrades available for the Zetec MAF? Can it be changed/upgraded with one from another ford i.e. focus?
'98.5 Contour SE - Zetec Powered
'00 Focus SE rims with Toyo FZ4's
Rickbrook Shifter Knob
Bullit Gas Door
Accel Coil with Ford Racing Wires
KVR Cross Drilled Rotors with KVR Carbon Fibre Pads
#292631 08/08/01 08:13 PM
Don't know about the availability of such a part but I think you should get some feedback on how to introduce more fuel into the mix as well.
If you only do an intake upgrade, it may cause you to run lean and then some of the performance may be compromised.
I like the idea and would like to know a working solution.
Kharma is very real and she is one mean b!tch.
#292632 08/09/01 02:09 PM
Heres one made for the focus zetec.
2000-up Zetec 70mm MAF ONLY (453-PF-70AD-MAF)....$209.00 kit.
Zetec MAF
**Spelling should not count**
2000 SE Zetec ATX
Medium Steel Blue (Now with large custom dent on the rear door)
Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
#292633 08/13/01 03:02 PM
Dont bother with the MAF or larger throttle bodies. Its the resonator above the TB and the rest of the plumbing that is killing your airflow.
Sort this out and its worth up to 25HP (seen on my local Dyno, with a Focus with a custom intake). Thats with the 60mm TB and standard MAF
Laminar fast flow is more important to the Zetec than volume. Larger flow means lower velocity and more turbulent flow and less power. you want long smooth fast flow
Mad Mole
Visit Mad Moles Mondeo Madness
2L Zetec, Cams, Stage 2 head, Valve work, Powerflow, Unichip, AEM Ram, K&N, Ecotek, 75mm Lower etc.
192 BHP, Faster than a speeding Duratec!
#292634 08/13/01 03:08 PM
MAdmole's right. At this point the TB and MAF are not the problem and would hinder perforamance.
They will be needed for turbo, SC, or very high HP outputs.
2000 SE Zetec ATX
#292635 08/13/01 06:54 PM
Madmole
Ok then if MAF and TB for the zetec is not going to solve anything, then if I got the super chip and MAF upgrade, does that make any sense?
What can I do to get that 25hp from resonator side.
P.S. Laminar flow is ???? I need a technical dictionary!
Thanks in advance!
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#292636 08/13/01 11:55 PM
4
4
There is an intake available from SCA that does eliminate that huge box above the throttle body.
Justin
'02 Ranger Edge ext cab
Retired: 98.5 Mystique
#292637 08/14/01 12:00 AM
You could use Air filter,superchip,fuel pressure regulator and this-
SCA Induction
My car:
1993 Mondeo 2.0 Si Saloon
145.8BHP
*RS wheelarches and bootspoiler*
*7x16" Team Dynamics Monzas*
*Cat back Powerflow exhaust with dual exits*
*K&N panel filter*
*Intake Resonator removed*
*Modified throttle body*
*Billeted Alloy Oil-Filler Cap from RSJ Manufacturing*
*Gas bonnet lifters*
*Sony CDX4180 CD head unit*
*Electric sunroof*
*Rear courtesy light*
*Footwell Lights*
*MEG Sticker*
Next mods:
Indiglos!!!!
Then i'm saving for a MK2...
** mondeosc.co.uk-Now updated!!Pics of Contours and Mystiques wanted. Apply within. **
#292638 08/14/01 08:28 AM
Laminar flow is when the air flows as a single mass with all the air streams parrallel and laminar. Turbulent flow is when the air is stired and tumbles and bounces around in a tube, like the Zetec Resonance chambers
The engine needs certain mass of air. You can take it down a thin, long and smooth tube as fast laminar flow (Good) or stick on a wider tube, which means the air flows slower and has more chance of becomming turbulent (Bigger TB and MAF)
The 60mm TB and MAF can flow more than enough air for a Zetec up to about 200BHP, then you can start to think about bigger units. Better to get the airflow sorted first
Mad Mole
#292639 08/14/01 11:36 AM
So, what type of MAF is stock 98 zetec! Do I want to increase or decrease stock size! Or is the stock MAF all i'll need? Thanks a bunch for the responses!!!
So I take it that this long silver tube (shown above), being as short as possible with no coil like restrictions actually help flow? I have seen these on Hondas!!!
2001 Cavalier
150-175 more kms
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
