#29211 05/13/01 05:08 AM
jjost Offline OP
Hope this pic shows...my intake setup on my '00 SVT.
[img]http://albums.photopoint.com/j/View?u=1670215&a=12805129&p=48373603[/img]
#29212 05/13/01 05:39 AM
E
E
Which sensor is it that must be relocated or drilled out in the BAT pipe? And is that pretty much how it comes from them, I mean did you add anything other than what it includes. I realize it is just the part from the MAF to the throttle body.
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#29213 05/13/01 06:49 AM
Is this merely aesthetic or does it provide some benefit possibly from smoother airflow?
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#29214 05/13/01 06:57 AM
Looks good, have the monster flow on my car too.
You should make a heat shied to cut out engine heat, and increase performance.
But just my 2 cents laugh
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
#29215 05/13/01 03:38 PM
jjost Offline OP
1) Eric: it is the air intake temp sensor. note the wires running to the air filter. And notice the plug in the right front tube on the BAT pipe. I drilled out the moulding on the filter and mounted the AIT there.
2) Dan: It should provide a little cleaner air flow and a small boost, but no dyno #s, so that's just a guess ( rationalizing all the $$$ ?). Does feel stronger at the top compared to the Injen I took off. The Injen set up is longer by almost 2". As you can see, that made a tight fit around the fender wall air inlet.
3) Chow: thanks ...I am working on a plexiglass box and aluminum air dam scoop, but haven't figured out how to prevent water from coming in too. Streets flood around here in the winter with any heavy rain.
jj
#29216 05/14/01 01:58 PM
that intake looks very similar to the WeaponR intake that SVT_Nate has...there is a pic of his on his website http://members.home.net/nate.is/
do you like that foam filter??
2000 SVT (silver)
#1529 of 2150
yeah...its modded
#29217 05/14/01 02:40 PM
jjost Offline OP
That is a nice loking set-up.
I like the monster flow alot .. very easy to work on for cleaning etc ...... jj
#29218 05/15/01 02:43 PM
W
W
Hey guys...
Regarding the Monster Flow filter....
I sent an email to the company but to no evail.... When I got the filter from SCA with my CAI pipe there were no instructions for cleaning the filter. I know with the KKM there is a process of oiling it after cleaning. What has to be done to the monster flow? Can you just clean it with water and re-install when it is dry? It has been on for a year and I am sure it could use a cleaning...
Thanks in advance for any help.....
Whitey
99 Blk/Tan SVT
SCA CAI w/ Monster Flow
#29219 05/15/01 04:43 PM
jjost Offline OP
Originally posted by Whitey:
Hey guys...
Funny you should mention that; I just sent my second email last on the same topic, no response yet ..... some of the Mustang guys use them and I anm in touch with a club in E. Texas if I get an answer I'll post. jj
#29220 05/15/01 05:09 PM
W
W
Thanks JJOST..
BTW, setup looks nice!
Whitey
99 Blk/Tan SVT
