Posts: 3,562 |
Anyone check out Gude performance lately? The heads and cam "Stinger" package adds up to 58 freeeking HP to the wheels (dealer estimates mid 40's without the TB on the tours). The TB that comes with the kit may be different due to manifold differences, but the rest should fit, I.E. ported head and cams... Damn boys, time to whoop some arese... The ZX2 guys are putting 2 cars lengths on a Prelude 2.2 Vetec with this kit... Price is $1450 for an introductory offer only... Add a header to that for even more HP!!!!!!!! http://www.gude.com/ Wish someone made this sheet for the V6...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 2,657 |
Damn, I need that. I bet that TB is pretty similiar to ours if not identical. That would be nice to be able to use the whole kit. I'd just like the new cams and head. This thing is exaclty what I need for some more power.
Administrator
Administrator
Posts: 5,037 |
Imagine what it would do with a turbo.
Master P
Master P
Posts: 5,455 |
I'd bet that the TB is different. On the Focus, the TB is different from MTX to ATX. Different gasket is required or some such nonsense.
I see all these crazy power adders when I surf around Focaljet. Port, Polish, & 7 Angle valve job for relatively cheap, Gude, turbos, superchargers, headers, etc. I usually don't waste my time posting because I know that there aren't too many people here (any?!) that have the big bucks to drop.
I'm about this --> " " close to ordering a header...
Posts: 569 |
I found them a whlie ago here'e what there head packege includes
ABSOLUTELY THE MOST POWER PER DOLLAR SPENT RULE THE STREETS REGULAR PRICE 1550.00 AND UP ON SALE MAY 2001 ALL PACKAGES FOR $1450.00 EXCHANGE ADD 100.00 FOR ZX2ZX3 & KA24 Niss. UP TO 50 HP GAINS AND BETTER GAS MILEAGE IN MOST CASES WILL PASS SMOG. THIS PACKAGE HAS PUT MANY SOHC 1600 CC CIVIC IN THE 13 SEC. GROUP AND STAY A DAILY DRIVER, WITH BETTER GAS MILEAGE CALL 909 244 3533 OR 909 245 7577 HEAD PACKAGE INCLUDES S ITEMS A TO H OR ANY COMBONATION OF. A. BIG BORE THROTTLE BODIE. B. PORTED INTAKE MANIFOLD C. PORTED POLISHED HEAD D. RACEING VALVE GRIND E. HIGH COMPRESSION RADUIS CHAMBERS F. CAMSHAFT GRIND TEAM CAM G. COMPUTER UP GRADE H. CAM INSTALL TOOL
FORD ZX2 FOCUS ZX3 98 UP A B C D E F H
So the TB should work since the packeg comes with a ported intake manifold.
They also have a turbo kit.
**Spelling should not count**
2000 SE Zetec ATX Medium Steel Blue (Now with large custom dent on the rear door) Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Posts: 3,562 |
Where are the people thinking about a Duratec swap? those guys must have the money if they thought they could afford that :rolleyes:... Come on Perry... What do we have to do to push you that last little bit? Golly, all I wanted to do was see a Zetec Contour do something like the Zetec Foci and Escorts are doing, snif
Posts: 569 |
Thats my first set of plans is to get the stinger Package before a turbo. Don't know I kind of want to keep it NA.
Master P
Master P
Posts: 5,455 |
Originally posted by bnoon: Come on Perry... What do we have to do to push you that last little bit? Golly, all I wanted to do was see a Zetec Contour do something like the Zetec Foci and Escorts are doing, snif Shoulda warned me, I would have put my waders on! The last edge is making sure that I can return the things if they don't fit. Long tubes would rock, but the only place I've found that sells them is FocusSport and they won't help me out.
Posts: 3,562 |
Originally posted by perry: Shoulda warned me, I would have put my waders on!
The last edge is making sure that I can return the things if they don't fit. Long tubes would rock, but the only place I've found that sells them is FocusSport and they won't help me out. Call Eric at BAT. He said he could get long tubes and would allow a return if it doesn't fit. The only way you can't return it is if it's completely installed and ran that way... Remember, I talked to Eric a month ago and announced this to the Zetec guys as an option... Perry, can you Email me, bnmotorsports@msn.com?
Master P
Master P
Posts: 5,455 |
Originally posted by bnoon: Call Eric at BAT. He said he could get long tubes and would allow a return if it doesn't fit. The only way you can't return it is if it's completely installed and ran that way... Remember, I talked to Eric a month ago and announced this to the Zetec guys as an option... Perry, can you Email me? Right, I called Eric about a month ago, and just called him again just now. No Focus headers in stock -- call again in a few weeks. ME WANT! The cat flange on the Contour and Focus is different, so short tube Focus headers won't bolt right up. Either make the downpipe a permanent part of the system (another $100 which puts me in range of the ZX2 Kamikaze headers that I can get now and return). Eric did mention that they have a set of long tube prototypes they are working on.... He doesn't know when they'd be ready, but my credit card is burning a hole in my pocket!
