Posts: 926 |
Im not very fimiliar with nitrous (Better with turbos). Would the ATX handle 100 shot?
Ben C '97 Zetec Sport ATX Pacific Green Fog Light Re-wire Many Mods My Site
You think you can beat this?.....Well, you probably can
Posts: 569 |
No, NOS is not better for FWD ATX. A turbo would be the better choice becuase the power is a gradual gain not a sudden burst, 100hp suddenly at the front wheels would pull like a Son of a *****. Plus the tranny wouldn't last very long.
**Spelling should not count**
2000 SE Zetec ATX Medium Steel Blue (Now with large custom dent on the rear door) Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Posts: 926 |
What about the MTX? It should handle a turbo and NOS. Just need a heavy duty clutch.
Posts: 9,178 |
The ATX is actually pretty sturdy. They use the same one for the Zetec as they do with the Duratec.
Posts: 926 |
The ATX IS strong enough for an 8 psi turbo, Ive found out. But I dont know about a turbo and NOS. That would require major Trans upgrades. Id like to get my car into the 10s or 12s
Master P
Master P
Posts: 5,455 |
100HP shot would ruin the tranny, if not the engine. A guy on the mailing list tried a 75 shot on his atx zetec a year or two ago. Ended up replacing the engine... YMMV.
Master P
Master P
Posts: 5,455 |
12's is possible NA if you go on a serious diet. Esslinger's ZX2 go into the 12s with ~200HP, but it only weighed 2000lbs.
Posts: 926 |
If I built up the internals with stuff from Esslinger and did the trans with stuff from Level 10 and put a 3/4 hybrid turbo on it with NOS, add larger injectors and a stand alone fuel management system. I bet I could hit 10s.
Posts: 38 |
If I were to add a NOS system, what would I need to replace in my engine to ensure that my pistons wouldn't shoot through my hood and my engine to melt down smtass4u@aol.com
Posts: 926 |
Originally posted by Timing: If I were to add a NOS system, what would I need to replace in my engine to ensure that my pistons wouldn't shoot through my hood and my engine to melt down smtass4u@aol.com It all depends on how much NOS your going to run
