here you go.........
Tip#8 - 105Mph Speed Limit Removal
May 18 1999
Difficulty: Moderate
So you want to disable your speed limit (AKA Governor)? Pictures coming up soon. Here ya go guys!! Remove your dual cup-holders and locate the wiring harness beneath them. Cut the black plastic piece surrounding the wires. Carefully find the white wire with the BLACK stripe. 'mere is a white wire with a green stripe... make sure that's not it Cut the white wire with the BLACK stripe. All done!
I added a toggle switch to my governor. For about 3 dollars, you can go to radio shack and buy a small switch. Connect one side of the governor wire to the center terminal, and one to whichever side you want. Drill a small hole in your center console, and mount the switch, I also had to buy a small reel of hook-up wire to lengthen the governor wire.
Your car should have a check engine light pop up after a couple days This is normal, don't worry The switch I use makes it so that my light doesn't come on for the governor.
www.ZX2.com or its creators WILL NOT be held responsible for any damage or financial compensations caused in whole or in part by the information held on this page. If you choose to disable your governor, please be responsible with it. Webmaster Zx2.com
And I don't Hold any liability to this mod.. but I've tried it, and it works pretty damn good!
