VCT = Variable Cam Timing. It's a heavy hydraulic mechanism inside the timing gear that with solenoid actuation and oil pressure, can advance the exhaust cam timing as much as 20 degrees.
This is done as a replacement for the egr valve, that by changing the intake/exhaust valve timing overlap, they can suck exhaust gas back into the motor to mix with the new air and fuel coming in during the intake stroke.
This takes away room for more good air and fuel, and creates a lean burn condition. Good for emissions, bad for power.
For those who'd like to discard the exhaust vct, I have adjustable cam gears and adapters so you can take off and chuck the vct exhaust gear, and dial in the right timing for more power.
ZXtuner Store 1999 ZX2 S/R
128.5 wheel hp @ 6250 rpm
9.62 sec @ 72.11mph (1/8)
2340 lbs.
