Administrator
Administrator
Posts: 5,037 |
Master P
Master P
Posts: 5,455 |
I sure hope David meant 6 - 7 in the 0-60 sprint, not the 1320 sprint.
Posts: 2,246 |
My bad, Perry was right, I meant 0-60. I must not have been thinking properly. Oops. Is that possible though or would it be faster? Also do you need an ATX shift kit upgrade? ------------------ David Litsky 96 Contour GL Clarion, Infinity, ESX, Alumapro "It is stupid to argue with idiots because you stoop down to their level and they beat you to death with experience" DaveL@drexel.edu
David Litsky AIM: DaveL225 My Car
Administrator
Administrator
Posts: 5,037 |
David, because you have an older Contour, I would recommend at least the Transgo shift kit. This kit helps keep the wearing parts safer as well as keeping a gasket from blowing. The earlier CD4E's where prone to a gasket failure due to runaway line pressure.
Posts: 2,246 |
I would seriously consider this as my car will be with me for 4 more years and the extended warranty is over in November. Especially if I can run 13's in the 1/4 mile, very worth it. Keep the outside looking stock and surprise the hell outta people. ------------------ David Litsky 96 Contour GL Clarion, Infinity, ESX, Alumapro "It is stupid to argue with idiots because you stoop down to their level and they beat you to death with experience" DaveL@drexel.edu
Posts: 372 |
Originally posted by Sasmaster6000: Now that I know the ATX can take at least a 6psi turbo its time to decide which one to get. Any ideas?
Jackson Racing S/C on the way for brothers ZX3. Looks like a clean install, question is, if a Turbo or S/C is CARB approved for the Zetec in a Focus, can we put one in a Contour .. my wife would be very happy with a bit more power ... jj [This message has been edited by jjost (edited May 02, 2001).]
Posts: 169 |
... go to a junkyard, find you a T25 turbo off of a TSi or Eclipse. it is small enough to spool up faster and provide more power, or you can buy a new one , or a T28, or T3/T4 from Garrett , they are basically the best turbos for a 4cyl.
1999 Mustang Cobra Red ------------------ PCM Reprogrammed STEEDA Billet Steel Flywheel STEEDA Tri-Ax Shifter STEEDA Ultra-Lite Rims STEEDA 30LB Injectors STEEDA Sport Competition Springs JBA Shorty Headers And the beast... Paxton Novi 1000 Supercharger (only $2500 Holy Sh!t) ------------------------------- No dyno yet, but definately more then 320 hp.
Posts: 4,042 |
David,
don't wanna burst your bubble, but you won't be running 13s with a Zetec and a ATX. Low 15s maybe.
You'd need MAJOR internal work and run extremely high boost to hit 13s.
Lets put it this way....
David Z. ran a 14.0 with his 3.0 SVT pushing 240 at the wheels, with a 5-speed. So, in order for you to hit 13s, you'd need AT LEAST 270-280hp at the wheels.
Good luck, but methinks that ATX ain't gonna handle it.
John
Posts: 2,246 |
John Somebody was telling me that it would run 13's. I guess that I want something that makes the car faster. Hell even low 15's is what, 0-60 in the upper 6's or so? That works for me.
Posts: 2,166 |
I think its possible to get a Ztec into the 14s with a turbo. I'm not sure about the Atx powered cars, but Ztec has alot of potential. I was looking at the specs of the FR200 and it seems that they are making 300hp with a stock connecting rods and crank. 300hp will definately be a low 14 possibly high 13 Check out http://www.fordracing.com/performanceparts/html/project-fr200.htm for more info...
