Posts: 106 |
Hi Y'all! Glad you found my store. Buy lots! lol The thermo does fit the Contour no problem... Anybody in the Riverside, CA area that can bring their car over to see if any other parts from the Zx2 fits (ie: udp, pots mods, coil, plug wires, cams, cam gears, yadda yadda...?) ------------------ ZXtuner Store 1999 ZX2 S/R 128.5 wheel hp @ 6250 rpm 9.62 sec @ 72.11mph (1/8)
ZXtuner Store 1999 ZX2 S/R 139.3 wheel hp @ 6900 rpm 9.62 sec @ 72.11mph (1/8) 2310 lbs.
Posts: 884 |
ROFL!! You guys are hillarious!
You can go to the parts store and get a 180F thermostat that will fit the car. No, I ain't giving you the part number 'cause you should be able to figure this out for yourselves. It's easy, just take a look at the 195F and compare it until you see the proper one...pssst, they also have a 180F listed in most AP computers; ie:Pepboys. Still, it isn't wise to go any lower.
But you're sure funny, like you struck gold! HAHAHAHA!
John
Master P
Master P
Posts: 5,455 |
zxtuner, what would that "Intake - ZXtuner Upper Intake Tube & Elbow" do on a Contour? Remove the plenum and the snorkle hose / massive resonator?
Someone go out to his shop at test fit that sucker! I have a feeling the TB sizes are different, but that should be a simple little fix if zxtuner is willing to help out. It'd sure make that KKM intake look real perty under da hood.
Posts: 1,195 |
im reasonably neer, and i would go out there but ive no cash and i know i'd wanna buy something.... argh
97 Zetec MTX Sport Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam) Dual Fiamm air horns Mk1 Mondeo Clear corners(and yes I made them fit....) Boston FS80's in the front
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com AIM: AphexTwinGrin
Posts: 884 |
I totally agree. I know the Focus TB is bigger than the Contour/Mystique so we can't use the nice straight tube that they have. Any ideas zxtuner?????
John
Posts: 106 |
zx2 t/b O.D. is 2.75", the intake tube other end's O.D. is 2.75" also. If it doesn't fit, I'll be happy to make one that'll work. My big Q is does the udp from the zx2 work on a Contour? C'mon, can someone stop on by? I promise not to sell you anything  ------------------ ZXtuner Store 1999 ZX2 S/R 128.5 wheel hp @ 6250 rpm 9.62 sec @ 72.11mph (1/8) 2340 lbs.
Posts: 106 |
Oh, and if anybody's interested in lightweight alloy rims, I can order 4x114.3mm bolt pattern ALT210's (13.25 lbs ea in 15x6.5, 15.25lbs in 16x7). Prices start at $137.00 each. I'm putting a set on my car tomorrow. 16x7 Wheels and 195/50ZR16 Dunlop SP9000 Tires together weigh in at 35.5lbs... light. Compare that to the 44lbs my 17" Focal R5's and BFG 205/40HR17's weigh. ------------------ ZXtuner Store 1999 ZX2 S/R 128.5 wheel hp @ 6250 rpm 9.62 sec @ 72.11mph (1/8) 2340 lbs. [This message has been edited by zxtuner (edited April 10, 2001).]
Posts: 1,195 |
Well, i am 120 miles away, but if there is no one closer, i could make it out there some time, but im sure there as got to be someone closer.....
Not that i dont want to help out, its just a rather long journey if im not going to be able to get something cool out of it...
If you want to contact me, i can be reached at Roknut@linkline.com
[This message has been edited by Plastique_synthetiX (edited April 10, 2001).]
Master P
Master P
Posts: 5,455 |
Cool, cool. Gotta clean my KKM filter this weekend, I'll just plop the plenum off and measure the OD and see what we find. I've measured it once before but can't remember the number to save my life. Was gunna try making something at Home Depot but couldn't find the right size, whatever size it was.
Posts: 118 |
I ordered mine yesterday, I'll let ya know how it goes and if it doesn't go, it was only $17
1995 2.0L Zetec GL ATX -KKM Intake -AR "Spyder"wheels -Tints @15% -3A Racing 85W Fog Lights -Freedom Design wing -GTS Blackouts -6 x 8 Pioneer Speakers -Ventvisors -Sony headunit -Blue Focussport wires -Flowmaster 40 Series, 2" Pipes -No Resonator -Monza 3" tip -Blue Brake Calipers
