#290663 02/12/01 02:57 PM
redhawk Offline OP
Is it possible to upgrade the inserts on the motor mounts on a zetec without having to jack the entire engine up?
I really want to get the Energy polyurethane inserts but want to know if this is a job I can do myself...
Anyone done this successfully?
Atlanta, GA
1999 Silver Frost 2.0 SE Zetec
K&N Filtercharger
Mintex Street Pads
BAT Rotors
Sony ES Mobile Xplod
Pioneer 3-way 6X8's all around
BAT Bright Whites
Kharma is very real and she is one mean b!tch.
#290664 02/12/01 03:52 PM
9
9
hey if you just upgrade to the svt front and rear mounts you won't need the inserts. i was wanting to know when i upgreaded my mounts so i called warren at kkm and he told me that they aren't really necessary. it seems to be okay with out the inserts. well they worked thou since i wrecked my car last night the mounts didn't break. hope this helps you
95 contour gl
zetec
kkm intake
sma strut tower bars
2,1/4 custom exhaust-borla muffler
focussport wires
silverstone spark plugs
mercury mystique 6-spoke rims
asp underdrive pulley
sp motorsports rear sway bar
spax and eibach
svt front and rear motor mounts
grizzly street clutch kit
kent cams
kent adjustable cam gears
next:
header(which might not work)
msd or jacobs ignition
quaife
#290665 02/12/01 05:32 PM
redhawk Offline OP
How did you get those installed? What is the real advantage over the OEM mounts with inserts?
I have an ATX...
Atlanta, GA
K&N Filtercharger
Mintex Street Pads
BAT Rotors
BAT Bright Whites
#290666 02/12/01 07:53 PM
9
9
can't do it with a atx. the mounts that you have you have to keep. you can't even put inserts in them.
95 contour gl
zetec
kkm intake
focussport wires
spax and eibach
kent cams
next:
quaife
