Posts: 316 |
hey therry i was reading about the bulldog box mtx. i was wondering the cost. what for lsd is used? will this work on my tour? how much different are the gear sets? are the ratio's clsoer together? some more info on the tranny would be great i've been looking at this now for anout 2 weeks and sounds good enough to get. thanks
95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust-borla muffler focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar spax and eibach svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears
next: header(which might not work) msd or jacobs ignition quaife
Posts: 5,805 |
Depends on the level,with upgraded diff(non-LSD)we hope to be looking at around 1500.The LSD could be a Quaife or the other supplier in UK.As regards ratios they will be on stream later this year from UK.The issue at the moment is with the gear cutters of the up graded diff material causing me some delay.As regards a Quaife dif box I could build you one within the next few months.regards TAH ------------------ V6 MTX 'Buy the tools and dodge the fools..." 'Its only nuts & bolts!' Terry's Website
Posts: 316 |
hey would would be the cost of that? i have my old mtx-75 here cuz i had to replace it about5 months ago. i replaced the old one with a brand new one from ford.so if you could give me a price range that would be great
Posts: 5,805 |
Can you e mail me your e mail adress and we can sort out the specs,shipping( where are you) or pick up etc regards TAH ------------------ V6 MTX 'Buy the tools and dodge the fools..." 'Its only nuts & bolts!' Terry's Website
Posts: 316 |
terry my e-mail address is Mets_1986@hotmail.com. this is something im looking into cuz within the next 5 months i will be adding a turbo. thanks
Posts: 5,805 |
Ok I'll mail you over w/end,regards TAH ------------------ V6 MTX 'Buy the tools and dodge the fools..." 'Its only nuts & bolts!' Terry's Website
