9
9
hey therry i was reading about the bulldog box mtx. i was wondering the cost. what for lsd is used? will this work on my tour? how much different are the gear sets? are the ratio's clsoer together? some more info on the tranny would be great i've been looking at this now for anout 2 weeks and sounds good enough to get. thanks
95 contour gl
zetec
kkm intake
sma strut tower bars
2,1/4 custom exhaust-borla muffler
focussport wires
silverstone spark plugs
mercury mystique 6-spoke rims
asp underdrive pulley
sp motorsports rear sway bar
spax and eibach
svt front and rear motor mounts
grizzly street clutch kit
kent cams
kent adjustable cam gears
next:
header(which might not work)
msd or jacobs ignition
quaife
Depends on the level,with upgraded diff(non-LSD)we hope to be looking at around 1500.The LSD could be a Quaife or the other supplier in UK.As regards ratios they will be on stream later this year from UK.The issue at the moment is with the gear cutters of the up graded diff material causing me some delay.As regards a Quaife dif box I could build you one within the next few months.regards TAH
V6 MTX
'Buy the tools and dodge the fools..."
'Its only nuts & bolts!'
Terry's Website
V6 MTX
Haines Motor Sports Inc,
9
9
hey would would be the cost of that? i have my old mtx-75 here cuz i had to replace it about5 months ago. i replaced the old one with a brand new one from ford.so if you could give me a price range that would be great
95 contour gl
zetec
kkm intake
focussport wires
spax and eibach
kent cams
next:
quaife
Can you e mail me your e mail adress and we can sort out the specs,shipping( where are you) or pick up etc regards TAH
V6 MTX
Terry's Website
V6 MTX
9
9
terry my e-mail address is Mets_1986@hotmail.com. this is something im looking into cuz within the next 5 months i will be adding a turbo. thanks
95 contour gl
zetec
kkm intake
focussport wires
spax and eibach
kent cams
next:
quaife
Ok I'll mail you over w/end,regards TAH
V6 MTX
Terry's Website
V6 MTX
