9
9
okay all i hear about is this big discussion on the v-6 ud pulley but never anything on the zetec. i've had mine on for about 4 moonths no problems. is this something that was inherited by the v-6 or does this go true for our little zetec engines? if so im going to rip mine off at once. thank you
95 contour gl
zetec
kkm intake
sma strut tower bars
2,1/4 custom exhaust-borla muffler
focussport wires
silverstone spark plugs
mercury mystique 6-spoke rims
asp underdrive pulley
sp motorsports rear sway bar
spax and eibach
svt front and rear motor mounts
grizzly street clutch kit
kent cams
kent adjustable cam gears
next:
header(which might not work)
msd or jacobs ignition
quaife
I'm going to put one on when I get around to it. The focus guys dont seem to have a problem. I also havent seen much discussion on the zetec and would be interested to see what people say (probably the same answer I would think) As Terry said last time "Cant change physics"
'99 Mystique GS ATX
K&N Glasspack & Flowmaster
UDP(still in box)
15" AR Carerra's
Alpine Sony & JL Audio Sounds (weapon-r on the way)
"for when 109 aint so fine" 83 Jag XJ6
'69 Chevelle SS
'99 Mystaque GS
N
N
I want to put one on my car but I also have a heavy pouding System in the car. Doesnt this pully reduce the RPM (Idle) of the car? Doesnt that also reduce the RPM on the alternator thus producing less power? I have two 200 Watt amps plus HeadUnit, EQ, plus 2 10" Bazooka tubes and Fog lights. This usually requires quite alot of power when they are all on at night time? Any problems with this and a pully installed?
Patel
I have a pretty demanding sound system in mine 300 watt amp 10" J.L. alpine head unit pioneer door speakers but I,m gonna try it. I have an ASP UDP. I put UDP's on the 94 Mustang GT I had before the Mystique and it was a problem. Even with a 130amp alternator and big battery it would die in traffic at night A/C blasting Tunes blasting I got real used to watching the voltmeter and gunning the engine to get it to charge. Car was power everything and had electrical problems before I put the pulleys on.
'69 Chevelle SS
'99 Mystaque GS
9
9
hey i have one kenwood 600 watt amp, foglights,head unit,6x8 pioneers all the way around and 1 10in jl audio 10w3-d2. i have no problems with power for the amp or anything. the ud pulley reduces the amount of power that it takes to run the various pulleies. it increases engine reaction time by spooling up quicker. this shoul clarify any concern about the pwoer buy i want to no if we still have the same problem as the v6 cars do. help us out terry just a simple yes or no will work on if it is going to be okay for us zetecc owners
95 contour gl
zetec
kkm intake
focussport wires
spax and eibach
kent cams
next:
quaife
H
H
I have an Esslinger UDP on my Zetec and have had no problems. It's probably the best HP for $$ I've spent. Some of the guys on our board www.focaljet.com also have the UDP with heavy duty sound systems and have not had any problems as well. Biggest complaint is the dash lights flicker at idle which is understandable as the alternator is being driven at lower RPMs at idle.
nishalp...it doesn't affect the RPMs of the engine, just the RPMs of the alt. pulley.
'00 Dirt Kona Focus ZX3
Team FocalJet: NorCal
Mods-Superchips, FocusSport CoolFlo CAI, MBRPCatback Exhaust, JBA Header, Esslinger UDP, Eibach rear sway bar, Magnecor 8.5mm wires w/Autolite plugs, KKM'00 WRC wing
[This message has been edited by Hooked Again (edited January 27, 2001).]
'00 Dirt Kona Focus ZX3156 FWHP, 130 Max Tq.
Jackson Racing Supercharger, 65mm throttle body, JBA Header, catback exhaust, gutted cat, CAI, Eibach Pro Dampers w/Sportline springs and Eibach F&R swaybars
I'm not getting into this issue again but as a comment all engines do have torsional vibration in varying degrees.I'd suggest you ask 'judge'who works for the OEM of the V6 damper his thoughts and any data on the Zetec.Regards TAH
V6 MTX
'Buy the tools and dodge the fools..."
'Its only nuts & bolts!'
Terry's Website
V6 MTX
Haines Motor Sports Inc,
9
9
hey terry what is the best was to get ahold of judge i was like to talk to him on this subject. thanks
95 contour gl
zetec
kkm intake
focussport wires
spax and eibach
kent cams
next:
quaife
Post for him on the 'General' or e mail me off forum for his e mail adress.
V6 MTX
Terry's Website
V6 MTX
W
W
What excatly will a new pully do for a stock Z-tec? Will there be any noticable diff.?
1997 Ford Contour GL (Pacfic Green)
2.0 L. 4 Cyl. Z-Tec
2 Rockford 12' subs & a 600watt Rockford Amp
2.0 L. 4 Cyl. Z-Tec
Aftermarket Foglights
