Page 2 of 5 1 2 3 4 5
tbunder Offline OP
dude, the key words in the orignal thread were "easiest homemade", not unbolt the whole intake, take it to a friends house, polish it on some antique machine along with your hands. yeah, duh, anyone can polish their intake and make it breathe better for more power, but the question was for easy homemade mods. not go to great lengths for better breathability mods.
i will always have a comeback! :o)
Hey,
TBunder, don't be such a tool. You used a relative term such as easy.
Easy for RubY meant painting his taillights. Easy for jpwesson was a little machine work. What is easy for one is probably nuclear physics for another.
Just smile and say cool, you can do stuff like that, I'd like to, but it's probably out of my league. Or sumptin like that.
Try some decaf today!
TB
Tony Boner
Candidate for ICBM Launcher
Personal: tboner@mvp.net Work: tony.boner@central.sun.com
Saving the computer world from WinBloze as Unix/Solaris/Java Guru * Sun Microsystems Rocks * http://www.sun.com
Goofing off with cars
Duratec Vehicles
This Just In, Tony has a "new" SVT
1998 Contour SVT E0 Stock
618/6535 Born On Date: 4/30/1997
2000 Mazda MPV (Yes 2.5L Duratec): Bone Stock
Non-Duratec Vehicles
Daily Driver: 1987 Buick LeSofa^H^H^H^HSabre 3.8L V6 -- 150HP AND 215ft/lbs torque smile
Tony Boner
The spirit of my post was how to do things cheapest. With good drawings and some basic knowledge of how to make things you could take a $40 junk throttle body to a local machine shop and have all the work except polishing and assembly done for $75-100.
This beats paying Gude $275 for their bored TB (good product by the way) plus sending your existing TB as a 'core'. Of course, with the Gude all you have to do is 'bolt it on' but you are out $275 plus shipping plus your original body.
Using a junkyard TB, I got to develop and perfect the TB without taking the original off the car. it took me about an hour to remove the original, bolt on the modified TB and adjust the throttle sensor.
In terms of difficulty, designing and building this TB is about as difficult as changing cam gears, and definiely easier than reprogramming the ECU, or port matching the intake to the head.
hey tbunder, chill!
he was only contributing to the thread, no need to go off on one at him. i'm glad he did post that, it's sounds inresting!
1994 GLX mondeo
K&N 57i Filter
16" ST24 alloys
stebel twintone airhorns
clear side indicators
powerflow exhaust
spax vsx shocks and springs coming....
Mondeo Enthusiasts Group!
webmaster@fordmondeo.org
WEBMASTER OF:
www.fordmondeo.org
Car I own:
lightly modded mondeo
Mondeo, Daddy of the Contour!
tbunder Offline OP
i just renamed this thread to how to find a junkyard throttle body and polish it to flow more air. is this a new idea? not! but im out and this thread went nowhere it was supposed to go. i guess there are no easy homemade free mods for the zetec. and you all chill!! an easy mod is one that can be done in one step and take less than 20 minutes while improving performance of the car. not block the lighting of your taillights(dumbest mod ive heard of btw)or take several steps to polish some tb. granted that will work, it is by no means an easy or time efficient mod. and not free either, as i know no junkyards that will give away throttle bodies to public citizens.
9
9
okay lets get back to the subject of the post. the easyest thing i've done so far is run a shop vac hose from the intake to the front bumper for more cool air. but i got a air scoop made that fits in the middle of the bumper between the support plastic pieces that go from the top to the bottom parts. it cost me about 20 for it. it is made from stainless steel. the shop vac hose hooks right up to it with just a clamp holding th hose to the scoop. the scoop is mount to the bottom with some self tapping screws. but im done for now.
95 contour gl
zetec
kkm intake
sma strut tower bars
2,1/4 custom exhaust-borla muffler
focussport wires
silverstone spark plugs
mercury mystique 6-spoke rims
asp underdrive pulley
sp motorsports rear sway bar
spax and eibach
svt front and rear motor mounts
grizzly street clutch kit
kent cams
kent adjustable cam gears
next:
header(which might not work)
msd or jacobs ignition
quaife
Check out Home Depot. There are a lot of parts you can make with 3" and 4" dia plastic pipe, flexible couplings and the like.
I replaced the restrictive inlet on my air box (ZX2 is tubular) with a flexible coupling and a part cut from a 3" black plastic 45 deg el. Works nice and cost less than $15 for everything.
Dang you guys. Didn't you read INTO his Topic?
Thunder Blunder here wants to know how to make mods that will make his car go faster or improve performance without spending money!! We know that's impossible so we really shouldn't entertain his ignorance. Then again, he also wants to know how to do the mods without using any tools at all!
Get off the list Bunder Blunder or whatever!!!
John
Z
Z
Take your seats out and paint the seat base assembly. I painted mine and if I had a scanner I would show you how good it looks. All you need is sandpaper, primer, and spraypaint.
Also, get rid of your doording guards and badging. Put a $3.00 mesh grill on.
Joe
'96 Contour
Zetec + mtx
-KKM
-ATP 5 Razze 16" wheels
-Nitto 450 205/40VR-16 tires
-Banzai 16" pre-muffler
-Dynomax Super Turbo muffler
-chrome tip
-Autometer tachometer
-black antenna
-aftermarket fogs
-blue-painted calipers and drums
-knauberized
-badgeless
-silver-painted seat base
-mesh grill
-KKM pedals
-Richbrook gear knob (silver)
-Weathertech front mats
-Sylvania Cool Blues (high + low)
-blued out lighting in footwells, glovebox, and trunk
-billet oil filler cap
[This message has been edited by Zetec (edited January 26, 2001).]
'96 Contour
Zetec + mtx
-KKM
-Dynomax Super Turbo muffler w/ tip
-black antenna
-aftermarket fogs
-knauberized
-badgeless
-mesh grill
-KKM pedals
tbunder Offline OP
hey JC PENNEY HIGHHAT, go **** yourself. obviously you're the goddamn idiot. everyone knows there are ways of improving performance with little or no money, i just wanted to see what you other zetecers knew, obviously nothing. sorry to have insulted your stupidity in such a harmful way(you're such a stupid mf). go back to bed with your mommy.
