#290280 01/17/01 11:25 PM
9
9
i was wondering if the svt e-brake cables are the same as 95 tour e-brake cables for my drum brakes?
95 contour gl
zetec
kkm intake
sma strut tower bars
2,1/4 custom exhaust-borla muffler
focussport wires
silverstone spark plugs
mercury mystique 6-spoke rims
asp underdrive pulley
sp motorsports rear sway bar
spax and eibach
svt front and rear motor mounts
grizzly street clutch kit
kent cams
kent adjustable cam gears
next:
header(which might not work)
msd or jacobs ignition
quaife
#290281 01/18/01 12:14 AM
Master P
Master P
Nope. SVT has discs in the rear.
#290282 01/18/01 02:57 AM
9
9
that is all need to know. this way i get the cables with the svt brake setup im going to put on my car
95 contour gl
zetec
kkm intake
focussport wires
spax and eibach
kent cams
next:
quaife
#290283 01/18/01 04:31 AM
Master P
Master P
Sounds like a pain.. ABS hardware, maybe new master cylinder, proportioning valve, spindle, etc etc.. not really sure that it's worth it for the marginal gain. Just put the SVT brakes up front and you'll be good ta go.
#290284 01/18/01 05:07 AM
9
9
perry
this is for you.look here if i wanted svt brakes in the front i would be doing that too. but i don't cuz i don't want to put some cheap bracket on just to have front svt brakes. i would spend the money for front brakes the right way and totally rebuild the front brakes with svt brakes. but guess what. THEY DON'T FIT!!!!!!!! oh by the way if i read right from a haynes manual both of the one for a 95 to 98 and a 98 too 2000. the the valve and master cylinder and the same. if i have to go out and buy them i will cuz i can. oh yeah buy the way if i would ever get aside you on a street i would just totally blow your doors in. i would love doing that so much. i take alot of pride im my car maybe too much to make it run and look excellent. so if you have something against or anything like that just back the f?ck off!!!!! later
95 contour gl
zetec
kkm intake
focussport wires
spax and eibach
kent cams
next:
quaife
95 contour gl
zetec
kkm intake
focussport wires
spax and eibach
kent cams
next:
quaife
#290285 01/18/01 05:21 AM
JVT Offline
Originally posted by 95zetecgl:
perry
Uhhhh. Take a chill pill hoser. You trying
start something? Don't think so. You
ESPECIALLY don't want to start anything with
Perry. I've seen him in person. He could
step on me and he'll think I'm an ant. And
I'm 6'4".
So, chill out tough guy. And SVT brakes
DO FIT. Genius.
Expect a response by Perry, SOON.
You're welcome.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#290286 01/18/01 05:26 AM
Master P
Master P
Does your Haynes manual also tell you that the rear brakes on all cars are the same? Guess not.
Cheap bracket? What's wrong with replacing the Ford anchor bracket that is on your car now with one that came off an SVT? Are you saying that the SVT anchor braket is cheap?Pick up SVT calipers, rotors, and pads, and you have the SVT brake setup up front. Did your Haynes manual tell you that the SVT brakes don't fit? Or are you making this part up, because they most certainly do fit behind stock 15" wheels, and they work well.
Where did I say you didn't take pride in your car? I just said that changing to disks in the back isn't worth it because you will see a marginal gain. Your time and money will be much better off put into putting brakes from the SVT onto the front of your car. More bang for the buck. Trying to save you some trouble, but I guess you are somewhat masochistic...
Good luck with the Jacobs..
Perry
Contour-L Admin
96 GL
perryw@bellsouth.net
#290287 01/18/01 05:30 AM
Hey KID, what are you on? Stop standing on your bottom lip when you talk/type and use spell and grammar check next time you post. I don't see what you saw in Perry's post that made you so upset. Why don't you just quit posting to the boards. The stuff you write just makes people shake their heads. I must say, you are ignorant of our cars if you think the SVT brakes won't fit. AND, the bracket on the brake kits for the retro is actually the Cougar caliper upper which is the newer SVT caliper set-up.
I don't EVER want to see a post like this again! Next time you'll be blocked and the thread will be deleted. No joke!
John "fully tired of the non-sense" Miks
#290288 01/18/01 05:52 AM
JVT Offline
Oh, can I call you a liar now too?
Mr. I-told-everybody-I-got-a-S4-so-you-all-could-be-jealous? http://contour.org/forums/Forum33/HTML/000099.html
or is it
Mr. No-it-won't-fit-no-way-possible
Can't fit SVT brakes? (this post)
or
Can't fit the Esslinger UDP and idler pulley?
http://contour.org/forums/Forum33/HTML/000045.html
Sounds like you need to do some studying.
I rest my case.
John
'98 Contour SVT with 'stuff'
http://home.carolina.rr.com/czech007/
[This message has been edited by JVT (edited January 18, 2001).]
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
#290289 01/18/01 01:43 PM
That guy is a moderator???
Hightower, get him outta here...
BTW- not only could perry squash you like a bug, his car would spin donuts around yours...
Perry has one of the best set-up cars that I have seen...
AND, I agree with him. 80% of your braking comes from the front of the car. Why would you mess with the part that only controls 20%?
Loser...
Atlanta, GA
1999 Silver Frost 2.0 SE Zetec
K&N Filtercharger
Mintex Street Pads
BAT Rotors
Sony ES Mobile Xplod
BAT Bright Whites
Kharma is very real and she is one mean b!tch.
