Posts: 156 |
Allright, was reading an older ZETEC post and noticed that you had the tach...
Tell me how you managed that...
I know no Zetecs came with it, where did you find it, how do you put it in, how to you hook up the tach, et cetera EVERY detail you have.
Randy
Posts: 3,774 |
i am off to continue drinking my way into 2001. as soon as i sober up, i'll give you the details.
-brian
------------------ 1995 GL Zetec MTX...Light Blue Born: July 1995 Purchased: November 1997 KKM Intake Superchip FocusSport Ignition Wires Autolite Platinum Pro Plugs WINTER PAWS: Blizzaks on stock 14 inchers!!! Bring on the snow! Viper 500+ Alarm Sounds by: Pioneer CD/Polk dB/MTX Subs/Alpine Amp Richbrook Shift Knob "Recontented" Foggies
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 316 |
look i got one for my zetec. i got my tach out of a 95 tour zetec auto. the way to get one is a junk yard. you have to get the right one so it works right. they should ask you the month and year the car was made and what engine is in it. you can't put a v6 tach in cuz they are calibrated different.
------------------ 95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust-borla muffler focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar koni's with h & r's svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears ford racing alum intake
next: header(which might not work) msd or jacobs ignition quaife
95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust-borla muffler focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar spax and eibach svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears
Posts: 1,089 |
Originally posted by AA737-823: I know no Zetecs came with it Not true. Mystiques have a tach standard, even with the zetec engine. ------------------ '98.5 Mystique GS ATX/re-contented door lights/K&N Filter/Energy Suspension Sway Bar Bushings/Mintex Street Pads/high-beam bulbs in low-beams/Pioneer DEH-P3100 receiver/Pioneer TS-A6855's in all doors [This message has been edited by 4cylmys (edited January 01, 2001).]
Justin '02 Ranger Edge ext cab Retired: 98.5 Mystique
Posts: 4,983 |
Originally posted by 4cylmys: Not true. Mystiques have a tach standard, even with the zetec engine. Yeah. When I rented a 99 Mystique last Christmas to drive to San Diego, it had a Tach. It was the typical Zetec/ATX rental setup. Wonder why Ford didn't go ahead and put in on the Contour. ------------------ P. Valdez Las Cruces, NM 1999 navy blue SE Zetec ATX Philips BlueVision 9006 bulbs Philips Premium 9005 bulbs Hella Optilux 1100 foglamps PIAA SW H3 bulbs Sidemarkers clear corners DRL Relay Llumar Platinum Plus 35% tint Maxxis UA603 205/60HR15 tires KKM Tru-Rev intake "Regla de los Contours!" www.geocities.com/patmvaldez
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Posts: 1,184 |
my 96 mystique came with a stock tac what do you mean they didn't come with the zetec
1996 Mercury Mystique stock (so far)
The leading cause of Atheism in the world are Christians, who accept Jesus with their mouth but walk out the door and deny him by their actions. (*DC Talks greatest hits. track 15)
Master P
Master P
Posts: 5,455 |
Zetec Contours generally didn't come with the tach.. Mystiques, being a Mercury product, have a few more amenities than Contours (rear dome light, sunglasses holder) and include the tach as part of the standard package. ------------------ Perry Contour-L Admin 96 GL
Posts: 5,805 |
The Contour 'Sport' with a Zetec,around 97 ,has a tac.
Posts: 156 |
allrighty then, so I go to the junkyard and tear up an early contour with a zetec and tach. How do I get into the dash to get at it? Once I have it, how do I put it in my car? Is the wiring all there? do I just get to plug something in, or is work actually required??
Thanks,
Allright, Baco, Happy New Year!!!!
Posts: 3,774 |
i am ready to be serious now.
i made the mistake of taking a guage cluster from a V6 contour. everything will work except the tach. the tach will need to be recalibrated using a little circuitry which i have not gotten around to making yet. and i will probably never get around to making. so, the tach is currently not installed. i have my old guage cluster and it works fine for now.
once you get the RIGHT guage cluster, you need to pop off the large black trim panel on the dash board. there are small access panels which you need to pop off to get to the screws for the big panel. i think there are 5 screws. once those are removed, unplug the buttons that live there. i just have the clock and the rear defroster...you might also have the TRACS button to unplug amongst others. carefully remove the panel. the black plastic is the cheapest stuff available and will brake easily, especially the A/C vents.
with that off you will be able to see the guage cluster in front of you. i think it is also held on with 5 or 6 screws. take them out and make sure not to loose them somewhere in the dash. slide the guage cluster out as far as you can so you can get to the wiring harnesses in the rear. there are two wiring harnesses that plug into vertical slots in the back of the panel. they have little clip things that you need to press on and then tilt the harness away from the clip thing and pull it out. if you just depress the clip, it will not pull out straight. you should tilt it slightly to get the little tabs at the base of the harness out without braking them.
once you have done that for both harnesses, pull the cluster out from the dash and get ready to swap in the new one. installation is the opposite of removal. plug it in properly and turn your car (and lights) on before you screw anything in. that way, if a bulb is burnt out, you can replace it at the same time. chart the milage you took the thing out on and the new mileage and get a new title from the DMV. that way if you plan on selling it to an outside party, you will have a legal record that you made a guage swap and the mileages will be legal.
you should be ready to roll.
if you want to try using a guage pod from a V6, i'll sell mine to you for $30 or whatever you think it is worth (i paid $50), but it'll take some work to get the tach to read right.
hope this helps.
also, in 1995, there was an option group for the regular Zetec contour which added the tach. you could have a Zetec Contour GL with tach and electric doors and windows. but not with manual doors and windows.
