Posts: 184 |
Any zetec's with headers installed yet? I've been looking at some of the zx2 headers with envy.
------------------ 1998.5 Prarie Tan contour,zetec,ATX KKM Focus Sports wires LUKs(they suck)metal white 9006 Steel mesh grill(looking for SVT bumper) Dexcool Mobile 1 Silver (w/ flakes) dash and trim 15" green neon under dash and seats Pre-98 console Code Alarm W/ remote start and keyless entry Semi-metallic Tint 50% Still need to decide on UDP.
1998.5 Prairie Tan contour,zetec,ATX KKM;Focus Sports wires;Steel grills;Dexcool;Mobile 1;4x 15" green neon;Pre-98 console;Recontented clock and door handle lights;Code Alarm Surestart LX;Tinted;Sony and Polk ICE
Posts: 316 |
you have to find out if the pipe is bent the same(down pipe) to get in the middle of the car for the exhaust. i have yet to find a header that will work
------------------ 95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust- dynomax magnum with hooker headers exhaust tip focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar koni's with h & r's svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears ford racing alum intake borla muffler next: header(which might not work) msd or jacobs ignition quaife
[This message has been edited by 95zetecgl (edited December 21, 2000).]
95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust-borla muffler focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar spax and eibach svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears
Posts: 5,805 |
Check some of the UK sites,most have Zetec headers .
Posts: 184 |
What about some of the zx2 headers that keep the stock cat? This is getting too depressing, there's so little aftermarket for such a nice car!
Posts: 316 |
why don't you put an exhaust system on instead. you will see more gain from that than a header. plus you want to put a header on a atx zetec. a mtx zetec will see more gainsw than a atx.i don't even have a header yet i went and did everything else. i could care less if i get a header. the stock manifold works great.
Posts: 546 |
BAT has a nice looking header for the ZX3, its only like 200 bucks! But then theres the question if it will fit. I live about 2 hours from there shop, guess i should go there. They also have a high flow inlet manifold, that looks like it will work! But its 475 bucks, to much for my liking.
Nick F. 01 Focus ZX3 MTX borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec Yes its a zetec, we were here before vtec, so we are not copying!
