Anonymous
Unregistered
Anonymous
Unregistered
I'm going to put new plugs in my wife's Mystique this weekend. I'm used to working on V8's where the back plugs are very hard to reach. This little 4-banger is like a wet dream to tune up! Everything is right there on top in plain sight! It's going to take longer to buy the plugs than replace them....
What I'm wondering is what type of plug would be the best? I'm thinking about Bosch +4's or maybe NGK? I've never used the Bosch before. Are they worth the price or should I just stick with simple Autolite plugs??
Thanks, Steve
------------------ Wife's Car- 1998 Mercury Mystique- 4 cylinder around town car My Car- 2000 Grand Prix GTP- Fully Modded- Supercharged 3.8 ass kicker
Master P
Master P
Posts: 5,455 |
I've used Motorcraft double platinums in my car with no problems. I don't think that Bosch makes a +4 for the Zetec. I feel that paying for anything more than Motorcraft is just a waste of money, unless you have a reason to get a different plug. ------------------ Perry Contour-L Admin 96 GL
Anonymous
Unregistered
Anonymous
Unregistered
I just called a local AutoZone store. He checked both the computer and the Bosch book and they don't list a +4 plug for the 2.0. I may just end up getting the Motorcraft platinum or the NGK platinum, both are about $3.99 each. I would think maybe the NGK would be better??
Steve
Posts: 70 |
What about the split fires, do any of you have those on your "tour"?
Posts: 316 |
i put autolites in my dads car and that thing runs better on them, then it does on ngk or motorcraft. both motor craft and ngk have been in the car. the autolites are a double platuim plug. they work good. im running silverstone's nology makes them. they are made for a zx2. nology part number is S1K. those are 10 to 12 dollars a piece. hope this helps
------------------ 95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust- dynomax magnum with hooker headers exhaust tip focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar koni's with h & r's svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears ford racing alum intake
next: header(which might not work) msd or jacobs ignition quaife a borla muffler( a loud one)
95 contour gl zetec kkm intake sma strut tower bars 2,1/4 custom exhaust-borla muffler focussport wires silverstone spark plugs mercury mystique 6-spoke rims asp underdrive pulley sp motorsports rear sway bar spax and eibach svt front and rear motor mounts grizzly street clutch kit kent cams kent adjustable cam gears
Posts: 235 |
Even if you could find them the Bosch +4 suck. Even Consumer reports said they do nothing. I have them in one car and they do nothing. Overpriced crap!!!!!!!!!!!!!!!
Anonymous
Unregistered
Anonymous
Unregistered
Thanks for the help guys. I ended up grabbing some Platinum Autolites. They were about $3.99 each. The store also had some double platinum NGK's that were over $10 each!! What a waste of money. Anyway, it was the fastest tuneup I've ever done! It took longer to put my tools away.
Thanks, Steve
Posts: 3,774 |
can you guys list part #s for the following...
autolite platinums motorcraft double platinums
thanks!!!
------------------ 1995 GL Zetec MTX...Light Blue Born: July 1995 Purchased: November 1997 KKM Intake Superchip AR 16x7.5 w/ Dunlop W-10 (205.50.16) Viper 500+ Alarm Sounds by: Pioneer CD/Polk dB/MTX Subs/Alpine Amp Richbrook Shift Knob "Recontented" Factory Instrument Cluster w/Tach "Recontented" Foggies
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 1,969 |
Shame on whoever mentioned Split Fires...
If you are seriously considering those, I have a bridge to sell you in Brooklyn...
Crap, simple marketing crap....
------------------ 1999 Silver Frost 2.0 SE Zetec Mintex Street Pads BAT Rotors Sony ES Mobile Xplod Stereo BAT Bright Whites
Kharma is very real and she is one mean b!tch.
Posts: 3,774 |
Am I correct in assuming that all that is involved in a tune-up for these cars is a spark plug/wire change? Is there anything else that needs to be replaced, cleaned, tweaked?
Soon to be added: FocusSport Wires (Blue) Accel EDIS ignition Autolite Platinum Pro's
