#289208 11/01/00 01:32 AM
Does anyone know how to install a tachometer in the zetec? I don't have one, but I want to install one? Are the wires there, for a plug in?
Nick
Nick, Sprout2287@aol.com,
'01 Focus ZX3, Red,
MTX, Injen Cold Air Intake, Kicker Speakers, subs, and amps, Dei Viper Alarm.
I was wondering that myself. I'd like to install a small tach somewhere on the dash.
P. Valdez
1999 navy blue SE
Zetec ATX
PIAA 9006/H3 bulbs
Philips Premium 9005 bulbs
Hella Optilux 1100 foglamps
Sidemarkers
DRL Relay
Maxxis UA603 205/60HR15 tires
No performance mods yet!
P. Valdez
1998 VW Jetta TDI
1.9L I4 direct injection turbo diesel
5 speed manual
no mods, no money
AIM:PackRatTDI
My exhaust smells better than yours.
the wires are all there. i'll take a look at the tach i have and let you know which contact of the wire harness is for power/ground/signal. i might do that tonight or tomorrow.
ok?
1995 GL Zetec MTX...Light Blue
Born: July 1995
Purchased: November 997
KKM Intake
Superchip
AR 16x7.5 w/ Dunlop W-10 (205.50.16)
Viper 500+ Alarm
Sounds by: Pioneer CD/Polk dB/MTX Subs/Alpine Amp
Richbrook Shift Knob
"Recontented" Factory Instrument Cluster w/Tach
"Recontented" Foggies
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
thank you
Nick
'01 Focus ZX3, Red,
Yeah, thanks! I figured the wires were there (why would ford use two separate guage wiring harnesses)
P. Valdez
Las Cruces, NM
1999 navy blue SE
Zetec ATX
PIAA 9006/H3 bulbs
Sidemarkers
DRL Relay
P. Valdez
1998 VW Jetta TDI
5 speed manual
no mods, no money
AIM:PackRatTDI
i haven't had a chance to take the dash apart again, but i will def do it by next weekend. i want to get my tach in there soon.
ok?
Born: July 1995
Purchased: November 1997
KKM Intake
Superchip
ASP Underdrive Pulley
Viper 500+ Alarm
2001 Infiniti G20t
1974.5 MG B GT
if you are looking at the BACK of the instrument cluster, you will see two wiring harnesses. a black one on the left (passenger side) and a white one on the right (driver's side). the white harness has all of the signals fr the tach and for most of the lights on the inst cluster. the signal or the tach should be Pin #8. which is the 8th pin up from the bottom of the harness. you can get power and ground from either the black or the white harnesses by tracing where the power and ground wires are for each guage pod.
hope this helps.
Born: July 1995
KKM Intake
Superchip
Viper 500+ Alarm
2001 Infiniti G20t
1974.5 MG B GT
Mine's the white wire w/black stripe behind the instrument panel. HTH John
2
2
Why not just get a cluster with the tach from a V6? Should plug in, same transmissions are used. At least one Mystique person I've seen posting has a cluster with tach in a Zetec car, and in Australia they have a tach for the Zetec.
2 Red Tours!
'96 GL V6 ATX - the wifes ride
'98 SVT with both options - my toy!
OF's TH fix / K&N / Glove Box Light / an dats it!
2 Red Tours!
