Page 1 of 3 1 2 3
#289041 10/10/00 12:48 PM
redhawk Offline OP
Anyone else experience a pretty rough idle? if so, how did you fix it? I am going to get new spark plug wires and maybe some new spark plugs.
BTW- the car has 45,000 miles on it and the spark plugs were just replaced about 10,000 miles ago.
1999 Silver Frost 2.0 SE Zetec
Sony ES Mobile Xplod Stereo
BAT Bright Whites
Kharma is very real and she is one mean b!tch.
#289042 10/10/00 12:51 PM
See if you still have it when you turn the heat/ac to the 'off' position.
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#289043 10/10/00 02:38 PM
redhawk Offline OP
Yeah. I have it all the time but it is less when the heat/AC is off. It does diminish however when the car is in neutral or park. But once you put the car in gear, it starts shaking and NVH...
Any ideas?
BAT Bright Whites
#289044 10/10/00 02:42 PM
Most Zetecs do go a little rough in ac/heat modeA(the a/c compressor does 'cycle' even in heat positions).If the trans fluid level is ok suggest you get the idle speed checked first.
V6 MTX
#289045 10/10/00 03:07 PM
redhawk Offline OP
What's a good way to get the idle speed checked?
BAT Bright Whites
#289046 10/10/00 05:22 PM
F
FFE Offline
F
I kind of have the same problem. But It does't start shaking it starts this wired sound of. after a little of gas. to about 1500 rpm it's steady with small breakes kind of like 1/16 rest in a song.
1996 Mercury Mystique stock (so far)
The leading cause of Atheism in the world are Christians, who accept Jesus with their mouth but walk out the door and deny him by their actions.
(*DC Talks greatest hits. track 15)
#289047 10/10/00 06:25 PM
redhawk Offline OP
I also have this rattling when I hit the gas suddenly. Sounds like a heat shield or something that rattles. It makes a sound like someone taking a couple of marbles and shaking them in a soda can.
BAT Bright Whites
#289048 10/10/00 06:46 PM
Idle speed check at the dealer,may want to look at mounts aswell.The rattle could be one of a hundred things,try to nail it down with it in gear,hood up ,need a helper.Regards TAH
V6 MTX
#289049 10/11/00 01:29 PM
i have the same problem when waitin at like a light of something.. car shakes a lil bit... when in N or park it doesnt do it anymore.. a while ago some1 told me to get a part checked for cracks the Tensioner Pulley ... go here http://contour.org/forums/Forum3/HTML/000846.html
he explains hope it helps im thinking of doing this also..
-afr0
ill let ya know if i try it before you do ..its doesnt bother me that much cuz i just turn the bass up a lil bit and i dont even notice
#289050 10/12/00 07:24 AM
I went to my ford dealer about a month after I got the car because of the rough idle, the guy in service said "it's a four cylinder, right." I said yes, he said "well that's your problem"
Nick
Nick, Sprout2287@aol.com,
'01 Focus ZX3, Red,
MTX, Injen Cold Air Intake, Kicker Speakers, subs, and amps, Dei Viper Alarm.
Page 1 of 3 1 2 3
