i just got back from pep boys and talked to some guy that owns a contour as well. well, he typed my information in for a credit card and i got approved. this led to the topic of me purchasing rims and tires so that he could buy my stock 15in rims that come on the GL models. so to my question, is it true, as he said, that you truly can not go any bigger than 15s without raising the strut tower or other miscellaneous work. the way i look at it is, if i already have 15s, why would i buy 15s. for all of you out there with 17s or bigger, did you have to modiy anything when you got new rims and tires? id appreciate any help possible. thank you all.
98 Toreador Red GL 2.0 ZeTec ATX
Hyper White Fog Lights
Xenon Blue Headlights
Interior Blue and Red lights
New Shift knob
Mirror Tinted Windows
Tweeters in all four corners of the ceiling
Kenwood Headunit (KDC-516S)
Cerwin-Vega three way 6x8's
2 MA Audio 12s (12DXi), a 2000 watt amp is on the way.
red brake caliber and drumb brakes
Mesh grills
and other misc. mods
7in widescreen tv with PS2
dmh0401@hotmail.com
http://www.geocities.com/marshlmathrs/My_Contour.html
no modification. sounds like the guy is a moron. just make sure the diameter of the tire is roughly the same as that of your stockers. use this as a calculator to figure out what size tire you need for whatever size rim you get.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
thanks alot, im trying to figure everything out before i go and purchase any rims and tires. would like to do it as soon as possible. thanks again. sorry, one last question, basically, you just buy the rims and tires, have them mounted and balanced, and you set to go? just curious. thanks again.
New Shift knob
Mesh grills
dmh0401@hotmail.com
yep
i went form 15" to 17" rims
the lower profile on the side walls keeps them the same "stock" diameter
just make sure the guy you talk to knows his ****
one place told me i need 205 45 17 to keep my stock profile, he said the 45 is all that matters
but the place i like and trust said a 215 45 is a slightly bigger side wall, 45% of the width or 215 would be a little larger than the 205 but iwts what i needed, makes sense if you do the math
both places incist their right :rolleyes:
To be installed:
-New BAT H20 Metal pump (got it)
-Bosch Platinum plugs (got them)
-9mm fordracing wires (on order)
-rear bushings clunk clunk arg!
-Intake when $$ is available
Installed:
-17" BSA Rims and Kumho 712's
-Pioneer Deck and 5x7's
-Side markers, ding strips gone
My ride 98 2.5 ATX : http://members.rogers.com/putz1979/contour/tournoding2.jpg
computer for sale (1800/512meg/60gig.gf3) http://members.rogers.com/putz1979/computer.htm
well, i just got back from Discount tire, got a credit card (500 limit), now i just need to save up the rest. thanks again.
New Shift knob
Mesh grills
dmh0401@hotmail.com
Moderated by  1314_dup1
