#285406 06/02/02 08:39 PM
JMSVT Offline OP
I was wondering if 17x7.5 in. Borbet Type T's
will rub with my H&R's ( with 215/45/17 tires )
Also would it be a good idea to go with
225/45/17 tires. Thanks for your input.
2000 CSVT BLACK w/ MODS
This is a good question because I too will be getting new rims, probably the Borbet type t's because I think the FSVT rims are going to be too hard to get and I'm going to be going with H&R's/Koni combo next spring. I know a 225/45/17 doesn't rub on stock suspension, even though when I bought my rims last year I was told that the 225 would rub, so I went with the 215 instead :rolleyes: My rims now, Millie Miglia Cellos, are 17 x 7.5 and I'm sure I could have gotten a 225 on there w/o any problems!
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
H
H
what's the offset of the borbet t's
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
JMSVT Offline OP
I believe the offset is 40mm
do you have a oic of these whee;s?
Black '98 Contour SVT
#162 of 6535
-Indiglo Gauge cluster-
-Kenwood KDC-X815-
-Audiobahn ALUM12x sub-
-Audibahn 18001d Digital Amp-
-Audiobahn 1.0 farad cap-
-LED side markers/washer nozzels-
-KKM Intake - Bosch Plat. +4-
-Custom Exhaust - NO res.-
-Sho Shop off road Y-pipe-
-Fog light fix - THX-Fix-
-Koni strurts - Roush springs-
www.geocities.com/svtour98 and most at http://community.webshots.com/user/svtour98 wink
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
I have the Borbet Type T's 17/7.5 on my car and yes they do rub. I originally shod them with 225/45 RE730's and the tires rubbed mainly in the back. Especially if there was anything in the trunk, or passengers in the back seat. Under hard driving all 4 tires will rub. After wearing out the fronts I have switched to the Khumo's ECSTA 712's in the same size (The Bridgestones are much better than this tire). They also rub, but not as bad. I am running the factory suspension with 25k on the car. If you have no problem with rolling the fenders, then rubbing should not be a problem. That is not an option for me because I Autocross the car and rolling the fenders is not legal in stock class. I have been very happy with the 225's on the car and the 17's. It handles significantly better than the stock tires(with the Bridgesones). In response to the Striped Brick, Tire Rack Carries the Factory SVT Rims for our car, but the cost was more than the Borbet so that is what I chose. Also, I have bent 2 of my Borbet's on potholes, so be careful to avoid potholes. And when asked why I did not avoid them I always reply. "I do not advise radical swerving at 110mph."
Hope this helps.
U
U
I have the type T's with Koni/HR and 215x45x17 Firestone Firehawk SZ50's with no rubbing. It used to rub with the stock struts and springs if I had anyone in the rear seat but after the HR/Koni combo it has been great and have not rubbed once even with 2 200+ lb guy in the back seat. The springs have settled a bit after 6 months but still no rub. If you want to see the hight I can take some pics and post.
I wonder whats up with all this rubbing because I had (4) people in my CSVT during SZ and I never heard/felt anything. I have 17" Millie Miglia Cellos w/ 215-45-17 and correct offset, so I wonder whats the problem with the other cars confused
Roger R
USMondeo@aol.com
1
1
I have the borbet t's but with eibach's and bat struts and mine rubs a little in the back when i have four people in the car plus my stereo but thats the only time.
2000 Svt
kkm intake w/heat shield, custom MAF,under-drive pulleys,braided brake hoses,carbon fiber brake pads,painted calibers,17x7 borbet t's with g-force tires,bat euro struts,eibach pro-kit,custom burned superchip,sho offroad y-pipe, bassani exhaust with high flow cat,formula one tint,kenwood excelon cd/mp3,mb quart compents w/mtx amp,b & m short shifter, carbon fiber pedals,hyper-bright bulbs,painted oval ring and many mods to come.
Moderated by  1314_dup1
