Page 2 of 2 1 2
#284704 05/01/02 10:07 PM
If you go to a 215 width, I'd drop to about a 55 profile. Dunno if anyone even makes a 215/55R15, but I suspect that would be closer to the same diameter as the 205/60R15's.
If you increase the width by about 5%, then you need to reduce the sidewall by about the same percentage.
FWIW,
TB
PS, if this link works, it is a list of TireRack's 215/50-15 tires. They had no 55 series in this width.
http://www.tirerack.com/tires/C ompare1....ark=1&do=Search
Looking at the Dunlop SP5000's, the 215/50-15 will turn 885 revolutions per mile, while your stock 205/60-15's will turn 847 revolutions per mile. This makes the stock tire larger than the 215mm wide replacement. So your speedo will read 4% too fast.
If you go with the 215/60, your tires will turn 808 revolutions per mile (even larger than the factory tire as stated before) and your speedo will read about 4% too slow.
Tony Boner
#284705 05/01/02 10:09 PM
My 2 cents:
DON'T GET FIREHAWK GTA'S!!
Thank you, that is all. wink
99 Black SE Sport ATX
Running on E1 SVT rims with Dunlop rubber
Pioneer DEH-P3100 CD receiver (2 channels of the amp blown, officially declared dead)
Pioneer DEH-P440 CD receiver
Pioneer TS-6865 6x8's in the front
Pioneer TS-6867 6x8's in the rear
Pioneer TS-WX121 Sub with a Pioneer GM352 amp feeding it
Page 2 of 2 1 2
Moderated by  1314_dup1
