Posts: 345 |
Took off the Blizzacks (mounted on steel wheels) about two weeks ago, put the stock E0's back on. Torqued 'em carefully. On the way home from work today I noticed a periodic 'thump' at low speeds and a 'knock' on turns. Found ALL 8 front wheel lug nuts loose - as in several turns each. I guess it is true - with aluminum wheels you're supposed to check/retorque after about 100 miles.
AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 134 |
yup same thing happened to me yesterday. thought that my wheel was going to fall off, now i'm all peranoid about my nuts :p
95'contour se painted interior/calipers 220wt.3-way door speakers hyfonics 100x2 amp w/audiobahn 12'subs no performance mods
Posts: 3,636 |
According to my tire guy, alloy wheels should be checked 100 miles after they are installed. I'm sure this goes for factory alloys as well.
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 3,419 |
I can't say I check the lugs 100 miles after a wheel gets pulled, but I've never had this problem (yet - knock on wood). What causes lugs on an alloy wheel to go loose after a short time? Just wondering, not that I doubt I should check them.
Posts: 3,636 |
My OZ's came loose, so I now believe in check them a day or two or 100 miles after installing/re-installing.
TB
Posts: 2,847 |
Yes, I belive the correct procedure is to check at 100 miles, and if you tighten them any, to recheck again at another 100 miles. I'll be bringing my torque wrench to SZ, checking periodically on my new wheels.
Posts: 778 |
Can someone explain the science behind why this is? Does it have to do with contraction/expansion of the metal alloy or what?
Posts: 411 |
Hey, all you have to do is tighten them with a torque wrench around 85 pounds. You shouldn't have any problems at all then.....
99 Tropic green svt Custom Stereo borla cat-back 22mm bat rear sway bar custom K&N & heatshield 215/40/ZR17 Rubber jimmkreider@yahoo.com
Posts: 878 |
Geesh. I thought this was only true for new aluminum wheels.
According to tirerack, the load-bearing metal around the lug holes may actually compress a bit, but once this is done, I didn't think it would happen again.
Lucky for me, I've never had this happen on my stock wheels, although I have noticed new wheels get a little loose the first time.
"Function before fashion."
'96 Contour SE
Posts: 240 |
i also thought/heard that it was only for first time mounting. and only for alloys, as yes, the first time the metal can compress enough to give room for the nuts to back off.
but i make a habit of checking them after 100 miles and each time i change the oil.
good luck! and torque safe! :-)
Please: put something meaningful in your post subject! NOT "please readme!". -------------------- "your" is possessive, "you're" is the conjunction that is short for "you are", "there" is for "the dictionary is over THERE", "their" is the possessive one, and "they're" is a conjunction that is short for "they are". have a nice day :rolleyes: -------------------- Silver Frost non-E1 SVT/Contour see my registry/profile: http://contour.org/carprofile/carprofile.cgi?a=display&uid=00004623
